Hi there,
with my server build Version 1.11.1.4768 on a Synology Diskstation subtitles won’t be recognized. I named all correct but they don’t appear, see the screenshots.
is the show actually matched?
I didn’t know 5-digit episode numbers are supported.
Yes, it’s matched. Also the naming works fine until yet with a lot of other series.
Is there a season folder? Subs fail often when it is missing.
Could you post the Plex XML info of one of those episodes?
I relocated the files to a season folder, unfortunately without success.
I added the media info, i think this is the requested xml, isn’t it.
Medien
Video Resolution 720p
Dauer 58:00
Bitrate 3429 kbps
Width 1280
Height 720
Aspect Ratio 1.78
Container MKV
Video Frame Rate NTSC
Audio Profile lc
Video Profile high
Teil
Dauer 58:00
File Onna Joushu Naotora - s01e00001.mkv
Size 1.39 GB
Audio Profile lc
Container MKV
Video Profile high
Codec H264
Bitrate 3429 kbps
Sprache 日本語
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Frame Rate 29.97 fps
Height 720
Level 4.1
Profile high
Ref Frames 9
Scan Type progressive
Titel DoA Encoder
Width 1280
Codec AAC
Sender Stereo
Bitrate 189 kbps
Audio Channel Layout stereo
Profile lc
Sampling Rate 48000 Hz
No, this is not the Plex XML. Please take a look at my link.
you’re right…sorry…
i added the xml right now… it’s funny cause my safari shows only an empty page so i had to use a different browser
OK, I only wanted to see the guid=
This says it is matched with TMDB.
Is this your default agent for tv shows/anime? If not, can you check that LMA is really activated for the TMDB agent?
@OttoKerner said:
OK, I only wanted to see theguid=
This says it is matched with TMDB.Is this your default agent for tv shows/anime? If not, can you check that LMA is really activated for the TMDB agent?
Thank you very much, this solved the problem. I changed the agent to my usually used TVDB with prober set of the local media asset option and it works instantly.
