PMS keeps crashing during its library scans
Issue: I just set up a new Plex server through Cloudbox (uses docker to set up PMS). I have begun adding libraries to PMS and scanning them. Every few hours, Plex seems to crash and I have to reboot it (through Portainer) to connect to it once more. My media files are hosted on Google Drive (Suite).
I am not watching anything through Plex while the libraries are being loaded.
Thank you!
Server Version#: 1.19.4.2935
Player Version#: N/a
Plex Media Server.log (148.0 KB) Plex Media Server.1.log (6.3 MB) Plex Media Server.2.log (10.0 MB) Plex Media Server.3.log (10.0 MB) Plex Media Server.4.log (10.0 MB) Plex Media Server.5.log (2.3 MB)
I can see 2 terminations of the Plex Media Server process with the process killed with signal 15 (Terminate)
Jul 20, 2020 15:17:10.877 [0x7f7424d5d700] DEBUG - Shutting down with signal 15 (Terminated)
Jul 20, 2020 15:17:10.877 [0x7f7424d5d700] DEBUG - Ordered to stop server.
and the next one was at
Jul 20, 2020 18:33:14.866 [0x7f5a24cc1700] DEBUG - Shutting down with signal 15 (Terminated)
Jul 20, 2020 18:33:14.866 [0x7f5a24cc1700] DEBUG - Ordered to stop server.
You will need to establish if it is being killed because of exceeding some pre-determined memory usage
How would I go about figuring that out?
Is there a docker configuration option ? If this is a hosted docker solution, then ask the hosting provider
