PMS keeps crashing on Synology DS1019
I am running cloudsync for my 225GB dropbox and I am unable to cancel the scan thinking that may be the culprit? Also it has only 61 photos in the 2 days it has been running, I have over 1000s of photos in my dropbox
Found a bunch of things. Thank you.
  1. [Notify] table (The linux default) is full. we need to adjust that .
  2. You turned off VERBOSE… Should have kept DEBUG on please. I had only asked to turn VERBOSE off. One more try there.
  3. THIS looks to be the root cause:
Jun 16, 2019 21:05:28.399 [0x7f5ec7fff700] ERROR - [Notify] Failed to add watch for "/volume1/Plex/Library/Application Support/Plex Media Server/Metadata/Albums/4/3187251ab964bce2ef0b6d64ac3dc25b24acd0e.bundle/Contents/com.plexapp.agents.plexmusic" (28: No space left on device)
Jun 16, 2019 21:05:28.400 [0x7f5ec7fff700] ERROR - [Notify] Failed to add watch for "/volume1/Plex/Library/Application Supp
You put media inside the Plex share, OR, You told Plex to look under Library for media.
The Plex share is for program use only.
Put your media in other shares YOU make.
Control Panel - Shared Folders - Create your media shares here.
As you create them, give user Plex permission to read the media.
When you refer to them in Plex, you use /volume1/Sharename in the library folder list.
I only made the Plex share visible to allow for easy access to log files.
I also put a notification in it to “Please do not add media here”.
Ok so I change the path of music to Volume1/music and Photos to Volume1/@Cloudsync which is my dropbox folder that has pictures, videos and files. do I need to cleanup space from the root to stop the crashing?
Yes. It looks like youv’e completely run out of space.
What does DSM show as free space for Volume 1 ?
Volume 1 says 9.61 TB free
Ok… And no media is inside the Plex share, No remote media mounted there, etc. The plex share is now left solely for PMS use?
You have moved your data mounts to another share?
Can you adjust PMS references (Library folder lists).
Restart PMS
Scan files,
Empty Trash,
Clean Bundles
Optimize Database
and pull a fresh set of logs? We might still need to adjust things
ChuckPA, I really appreciate all that you have done for me however it is getting late and I need to go to bed, is it possible I can get someone like you or anybody to call me this week to discuss this with me and help me out?
The only support Plex provides is through the forum. There is no “Premium Support” service like you request. It was suggested but nobody was willing to subscribe to it.
Plex isn’t Apple w/ Apple Care optional support . Hopefully someday, but not yet.
