PMS not adding Music
Server Version#: 1.40.0.7998
I recently moved for PMS from Windows to unRaid. I ended up doing a full fresh install due to some issues moving metadata over. So far I’m not having any majors issues. But for some reason, PMS no longer detects any Music files. Movie and TV Shows are perfectly fine. I have a /Music directory with all the same files that worked fine when I was on Windows. I have checked all file permissions and they are all the same as the Movie files (That are working perfectly). For some reason when I scan the Music library, I can see in the Dashboard that it sees each artist folder, but if never adds any of the 100s of mp3s to the Library. I was going to attach the logs files. But I get a 500 Internal Server Error when trying to do so, not sure if that is related.
When I open the console view and watch, the only errors I see are
Unknown metadata type: folder
And when I do a Music Library Scan I see “Error parsing content.” and “Error parsing XML: Error parsing file.”
Looking for some help on this
