PMS not picking up "Ava (2020)" movie
Server Version#: 1.20.1.3213
Player Version#: Windows 1.17.0.1376-439f8b7f
directory/movie name:
Ava (2020) # ls
Ava 2020 WEBDL-1080p.mkv
I’ve tried every which way to get plex to scan/add this but it just wont discover. I’ve had zero issues with any other movie. Turned on debug/verbose logging and got the following in the PMS.log:
root@plexmediaserver:/opt/plexmediaserver/config/Library/Application Support/Plex Media Server/Logs# grep "Ava (2020)" *.log
Plex Media Server.log:Aug 22, 2020 22:05:33.101 [0x7feaee5e1700] VERBOSE - Adding subdirectory for scanner: "/nfs/media/Movies/Ava (2020)"
Plex Media Server.log:Aug 22, 2020 22:05:33.268 [0x7feaee5e1700] DEBUG - Scanner: Processing directory /nfs/media/Movies/Ava (2020) (parent: yes)
Plex Media Server.log:Aug 22, 2020 22:05:33.269 [0x7feaee5e1700] VERBOSE -     * Noting that 'Ava (2020)' was updated at 2020-08-22 15:57:11
Plex Media Server.log:Aug 22, 2020 22:05:33.269 [0x7feaee5e1700] VERBOSE -     * Taking directory 'Ava (2020)' (16112) out of the map (1326 left)
Plex Media Server.log:Aug 22, 2020 22:05:33.269 [0x7feaee5e1700] VERBOSE - Adding file for scanner: "/nfs/media/Movies/Ava (2020)/Ava 2020 WEBDL-1080p.mkv"
Plex Media Server.log:Aug 22, 2020 22:05:33.270 [0x7feaee5e1700] DEBUG - Skipping over directory 'Ava (2020)', as nothing has changed; removing 1 media items from map.
Which looks like it’s detecting something, but it never adds. Once it finishes scanning and I try to search for it, it doesn’t show anything:
Edit:
looks like somone already reported:
fixed by splitting onward, then “fixing match”
Note:
Verbose Logging Useless
(exactly as indicated - DO NOT ENABLE unless specifically instructed to do so)
This worked instantly and perfectly:
As did this some time ago:
Hi! Sorry, for the newbie question. Can someone explain a bit more what “fixed by splitting onward, then “fixing match”” means?
Apparently the movie Ava and the movie Onward were linked as a duplicate. Splitting these results in two listings for Onward. Examining each of those for the filename indicates which one should have Fix Match applied.
“Splitting” 101:
Successss!!! This helped a LOT! Thank you Frederick!!
This was also VERY helpful and informative about possible issues! thank you JuiceWSA!
Sorry if this wasn’t clear, I assumed everyone knew what splitting was.
