PMS on Synology and adding additional media from a different Synology NAS
I’m running PMS on a DS420+ and I have mounted a shared folder from another DS413+ NAS via NFS that contains media files. I can see the files in the mounted folder via File Station. However, when I go to add that media folder to my Plex library from that mounted folder it is not visible in “Manage Libraries”. I can only see folder/files that are local to the DS420+.
Is this a permissions issue? A Plex Server settings issue? Or just a limitation of the NAS version of PMS.
Thank you
Server Version#: 1.21.1.3830-6c22540d5
That worked!!
Thank you for the detailed and informative reply.
