I grew up in Koenigstein/Taunus long ago when was still east/west
Last time in Berlin almost 20 years now. Family lived on Pragerstrasse at the time.
You are having performance issue because of subtitle burning.
SRT subtitles can be streamed easily by almost all players – unless player forces BURN option. Set player to automatic.
VOBSUB, PGS, DVDRIP are images – must be burned into each frame.
DSM struggles with this.
25% of a quad core CPU for subtitle burning (a whole thread)
15-20% for audio processing.
Jul 11, 2021 17:10:51.286 [0x7ff980232b38] DEBUG - [Transcode] Auth: authenticated user 1 as WaveDave
Jul 11, 2021 17:10:51.295 [0x7ff980232b38] DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
Jul 11, 2021 17:10:51.295 [0x7ff980232b38] DEBUG - [Transcode] Selecting best audio stream for part ID 12936 (autoselect: 1 language: en)
Jul 11, 2021 17:10:51.295 [0x7ff980232b38] DEBUG - [Transcode] We're going to try to auto-select a subtitle.
Jul 11, 2021 17:10:51.295 [0x7ff980232b38] DEBUG - [Transcode] Subtitles: Found a candidate subtitle language [eng] for a foreign film
Jul 11, 2021 17:10:51.295 [0x7ff980232b38] DEBUG - [Transcode] Audio Stream: 32009, Subtitle Stream: 32010
Jul 11, 2021 17:10:51.296 [0x7ff980232b38] DEBUG - [Transcode] Found session GUID of fvbnhn8ryvc2xuxnc3ebw7la in session start.
Jul 11, 2021 17:10:51.296 [0x7ff980232b38] DEBUG - [Transcode] Cleaning directory for session fvbnhn8ryvc2xuxnc3ebw7la ()
Jul 11, 2021 17:10:51.296 [0x7ff980232b38] DEBUG - [Transcode] Starting a transcode session fvbnhn8ryvc2xuxnc3ebw7la at offset -1.0 (state=3)
Jul 11, 2021 17:10:51.297 [0x7ff980232b38] DEBUG - [Transcode] TPU: hardware transcoding: using hardware decode accelerator vaapi
Jul 11, 2021 17:10:51.297 [0x7ff980232b38] DEBUG - [Transcode] TPU: hardware transcoding: zero-copy support present
Jul 11, 2021 17:10:51.297 [0x7ff980232b38] DEBUG - [Transcode] TPU: hardware transcoding: not using zero-copy because subtitle burning is required
Jul 11, 2021 17:10:51.297 [0x7ff980232b38] DEBUG - [Transcode] [Universal] Using local file path instead of URL: /media/Movies/Wild Mountain Thyme (2020)/Wild Mountain Thyme (2020).mkv
Jul 11, 2021 17:10:51.297 [0x7ff980232b38] DEBUG - [Transcode] Codecs: hardware transcoding: testing API vaapi
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x41524742 -> bgra.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x42475241 -> argb.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x41424752 -> rgba.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x52474241 -> abgr.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x58524742 -> bgr0.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x42475258 -> 0rgb.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x58424752 -> rgb0.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x52474258 -> 0bgr.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x30335241 -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x30334241 -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x30335258 -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x30334258 -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x36314752 -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x50424752 -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x50524742 -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x56555941 -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x30303859 -> gray.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x3231564e -> nv12.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x3132564e -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x32595559 -> yuyv422.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x59565955 -> uyvy422.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x32315659 -> yuv420p.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x30323449 -> yuv420p.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x50313134 -> yuv411p.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x48323234 -> yuv422p.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x56323234 -> yuv440p.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x50343434 -> yuv444p.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x33434d49 -> unknown.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Format 0x30313050 -> p010le.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Created surface 0.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] [FFMPEG] - Direct mapping possible.
Jul 11, 2021 17:10:51.298 [0x7ff980232b38] DEBUG - [Transcode] TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
Jul 11, 2021 17:10:51.299 [0x7ff980232b38] DEBUG - [Transcode/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/fa235d6-3858-linux-x86_64/' LIBVA_DRIVERS_PATH='/usr/lib/plexmediaserver/lib/dri' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'h264' '-hwaccel:0' 'vaapi' '-hwaccel_fallback_threshold:0' '10' '-hwaccel_device:0' 'vaapi' '-codec:1' 'dca' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/media/Movies/Wild Mountain Thyme (2020)/Wild Mountain Thyme (2020).mkv' '-filter_complex' '[0:2]scale=1920:1080[0];[0:0][0]overlay[1];[1]scale=w=1920:h=1080[2];[2]format=pix_fmts=nv12[3];[3]hwupload[4]' '-map' '[4]' '-metadata:s:0' 'language=eng' '-codec:0' 'h264_vaapi' '-b:0' '37852k' '-maxrate:0' '50470k' '-bufsize:0' '100940k' '-r:0' '24' '-force_key_frames:0' 'expr:gte(t,n_forced*1)' '-filter_complex' '[0:1] aresample=async=1:ocl='\''5.1'\'':rematrix_maxval=0.000000dB:osr=48000[5]' '-map' '[5]' '-metadata:s:1' 'language=eng' '-codec:1' 'aac' '-b:1' '774k' '-f' 'dash' '-seg_duration' '1' '-dash_segment_type' 'mp4' '-init_seg_name' 'init-stream$RepresentationID$.m4s' '-media_seg_name' 'chunk-stream$RepresentationID$-$Number%05d$.m4s' '-window_size' '5' '-delete_removed' 'false' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/fvbnhn8ryvc2xuxnc3ebw7la/3bab6dc5-4d02-4c5c-8b60-275f4554a4a2/manifest?X-Plex-Http-Pipeline=infinite' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-init_hw_device' 'vaapi=vaapi:' '-filter_hw_device' 'vaapi' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/fvbnhn8ryvc2xuxnc3ebw7la/3bab6dc5-4d02-4c5c-8b60-275f4554a4a2/progress'
