PMS on Synology NAS DS1817 is constantly crashing
Server Version#: 1.41.5.9626–70009626
Hi
My PMS is constantly crashing since a few days. I need to relaunch the PMS manually. Id’ like to have some help to solve this problem. I’m not a crack in handling a server like most of you, my skills are relatively basic.
It started a few days ago. These are the following steps I tried.
1/ I installed the latest version, Keeps crashing.
2/ I performed a complete uninstall, with removal of PMS share. Did a clean install with the version Synology delivers in their Package Center. Keeps crashing.
What do I need to do.
Using FileStation,
Navigate into the PlexMediaServer shared folder.
Drill down through AppData / Plex Media Server
Right-Click LogsCompress to Logs.zip
Download that ZIP file and attach here.
Logs.zip (1.1 MB)
Here is the logs.zip file
Thanks for your help
Thanks for the logs.
I am not seeing ANY errors.
When this happens, it usually ends up being a damaged database.
How good are you at using SSH (command line) ?
I ask because there is a tool to help check the database, fix it, or replace it with a known-good backup (something from before this started happening).
If you look here
Look at the documentation (the README.md)
It will show how to install and run it on Synology.
If you have ANY questions, please ask.
