PMS says recording failed but it still recorded it
Server Version#: 1.15.1.710 on Mac mini (Late 2012)
Player Version#: 1.39 on Apple TV 4
I was watching a recorded film last night using Plex, when I saw a message coming up on the screen saying, that the recording for “Trapped Episode 6” that was scheduled to start at 21:50 had failed.
I went into Plex o my iPhone and went into the schedule for this episode to trigger the recording attempt again but every time it displayed the same message that the recording failed. Eventually, I gave up but later I found that it had recorded the programme after all.
I have a full set of logs; here’s an extract of my recording attempts:
Mar 02, 2019 21:45:00.583 [0x70000c928000] DEBUG - Streaming Resource: Terminated session 0x7f7f9c36cbe0:e12934d3-4b59-4c9b-9c04-1dc5491328fc with reason Recording failed. Please check your tuner or antenna.
Mar 02, 2019 21:45:00.583 [0x70000c281000] ERROR - DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Mar 02, 2019 21:45:00.583 [0x70000c281000] DEBUG - DVR:Grabber: Operation for 'Trapped - E6 - Episode 6' on channel 107 completed with status error (Recording failed. Please check your tuner or antenna.)
Mar 02, 2019 21:47:33.879 [0x70000b8c8000] DEBUG - Streaming Resource: Terminated session 0x7f7f96199180:904987e0-b3fe-41d1-ad47-a0030123a367 with reason Recording failed. Please check your tuner or antenna.
Mar 02, 2019 21:47:33.880 [0x70000c0f8000] ERROR - DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Mar 02, 2019 21:47:33.880 [0x70000c0f8000] DEBUG - DVR:Grabber: Operation for 'Trapped - E6 - Episode 6' on channel 107 completed with status error (Recording failed. Please check your tuner or antenna.)
Mar 02, 2019 21:50:56.997 [0x70000c79f000] DEBUG - Streaming Resource: Terminated session 0x7f7f96199180:251f973c-86ee-4255-a9cf-ce7b183ca19e with reason Recording failed. Please check your tuner or antenna.
Mar 02, 2019 21:50:56.997 [0x70000c1fe000] ERROR - DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Mar 02, 2019 21:50:56.997 [0x70000c1fe000] DEBUG - DVR:Grabber: Operation for 'Trapped - E6 - Episode 6' on channel 107 completed with status error (Recording failed. Please check your tuner or antenna.)
Mar 02, 2019 21:55:05.124 [0x70000c1fe000] DEBUG - Streaming Resource: Terminated session 0x7f7f96d66dd0:c9658a3a-7b79-453e-88fb-9b39d69affa2 with reason Recording failed. Please check your tuner or antenna.
Mar 02, 2019 21:55:05.124 [0x70000c510000] ERROR - DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Mar 02, 2019 21:55:05.124 [0x70000c510000] DEBUG - DVR:Grabber: Operation for 'Trapped - E6 - Episode 6' on channel 107 completed with status error (Recording failed. Please check your tuner or antenna.)
Mar 02, 2019 21:55:14.816 [0x70000bce0000] DEBUG - Streaming Resource: Terminated session 0x7f7f95f1b480:9d258e1a-05f3-46e9-9017-466b7fb822c7 with reason Recording failed. Please check your tuner or antenna.
Mar 02, 2019 21:55:14.816 [0x70000c387000] ERROR - DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Mar 02, 2019 21:55:14.816 [0x70000c387000] DEBUG - DVR:Grabber: Operation for 'Trapped - E6 - Episode 6' on channel 107 completed with status error (Recording failed. Please check your tuner or antenna.)
And here is an extract showing the completion of the recording:
Mar 02, 2019 22:23:24.916 [0x70000cdc3000] DEBUG - DVR:Grabber: Setting timer to stop grab of 'Trapped - E6 - Episode 6' on channel 107 in 1296 seconds.
Mar 02, 2019 22:23:24.917 [0x70000cdc3000] DEBUG - DVR:Grabber: Scheduling 'Trapped - E7 - Episode 7' for timed grab at 2019-03-09 20:55:00 (in 599496 seconds)
Mar 02, 2019 22:23:24.917 [0x70000cdc3000] DEBUG - DVR:Grabber: Scheduling 'Trapped - E8 - Episode 8' for timed grab at 2019-03-09 21:40:00 (in 602196 seconds)
Mar 02, 2019 22:23:38.569 [0x70000b015000] DEBUG - There were 1 top-level paths for Trapped (2015).
Mar 02, 2019 22:23:41.111 [0x70000cdc3000] DEBUG - There were 1 top-level paths for Trapped (2015).
Mar 02, 2019 22:35:21.666 [0x70000c075000] DEBUG - There were 1 top-level paths for Trapped (2015).
Mar 02, 2019 22:35:26.637 [0x70000b015000] DEBUG - There were 1 top-level paths for Trapped (2015).
Mar 02, 2019 22:36:43.837 [0x70000bf6f000] DEBUG - There were 1 top-level paths for Trapped (2015).
Mar 02, 2019 22:45:00.921 [0x70000c387000] DEBUG - DVR:Grabber: Cancelling operation for 'Trapped - E6 - Episode 6' on channel 107 with status complete.
Mar 02, 2019 22:45:00.921 [0x70000c387000] DEBUG - DVR:Grabber: Operation for 'Trapped - E6 - Episode 6' on channel 107 completed with status cancelled (Success)
Mar 02, 2019 22:45:01.136 [0x70000b94b000] DEBUG - DVR:Recorder: Asked to stop recording 'Trapped - E6 - Episode 6' on channel 107.
Mar 02, 2019 22:45:01.330 [0x70000b94b000] DEBUG - DVR:Grabber: Recording for 'Trapped - E6 - Episode 6' on channel 107 stopped with status complete.
Here’s a full set of logs:
Plex Media Server Logs_2019-03-03_00-05-04.zip (4.1 MB)
