PMS showing double database whenever something is being streamed
Hello!
Whenever someone starts streaming something from my plex server, the PMS application (as in the 127.0.0.1 address opened by double clicking on the tray icon) shows double the streams and double the databases (first screenshot attached). If I try to click on one of the databases, I get the error attached in the second screenshot. If I try to search anything, results will appear, but if I hit enter, nothing happens. Clearing chrome’s cache and cookies will sometimes fix the issue but not always, and it only happens when I open PMS through the tray icon. The regular web app shows everything normal. This was happening on my old desktop, and I just installed a brand new instance of plex on a brand new desktop and it’s doing the same thing. Any help would be awesome!
Thanks.
Double%20database Error
Are you using the hosted web app? app.plex.tv
If not, try it, please.
Yea it looks fine there, it’s only screwed up when using the PMS tray icon. When its using the local ip address that’s when its wrong. Not a huge deal I know but kind of annoying.
The fixed version (which is currently on app.plex.tv ) will come eventually with an updated plex server version, so it can be used locally again.
Ah gotcha. Sounds good…thank you!!
