PMS v1.4.1.3362-77c6a4f80 includes built-in DVD-ordering option for TheTVDB Agent
Hooray!
Please note that this means I will no longer be updating my modified TheTVDB.bundle, and anyone using it should stop.
absolute would be nice too
Does not seem to work…
Hide Seasons… does not worrk
Episode order: DVD … does not work
Unfortunately I’m with @rossinior on this one - I can’t seem to get DVD ordering to work either. I tried refreshing the show in question, and even went to so far as to remove and re-add the files from Plex entirely, which didn’t help. It would appear that if the DVD order feature works, it doesn’t work for everybody. :frowning:
@phrawzty Which PMS server version are you working with?
@rossinior
$ dpkg -l | grep plexmediaserver
ii  plexmediaserver                     1.4.3.3433-03e4cfa35                amd64        Plex organizes all of your personal media so you can easily access and enjoy it.
I upgraded to 1.4.3.3433 also.
Hide seasons works now.
DVD order is not longer an option that my library edit dialog shows :neutral:
I definitely have the DVD order option…
Make sure you are using the local web app and not the plex.tv version?
I always use the local web apps, I have Plex Pass Windows and QNAP Versions of PMS, both at the latest version.
I only looked at the wrong Dialog (was checking the library Advanced Settings, not a single series). I have it there…
Will test the DVD order feature once I get the chance.
@Qwertz said:
Hooray!
I know this is an old thread, and I’m being a bit selfish, but…
The native DVD ordering option does not allow for decimal episodes (e.g., kids shows that air two segments in one 30-minute episode are tagged by metadata agents as separate episodes, and identified in DVD ordering with decimals, like episode 1.1 and 1.2). Tvdb and tmdb are rigid in their system and won’t change.
As I understand it, your DVD ordering plugin handled this wonderfully. Any chance you can revive it or assist Plex in incorporating it into their implementation? As it stands, trying to DVR shows for my kids (Daniel Tiger, Curious George) results in a messy situation where no metadata is correct and finding specific episodes is tedious. Manually fixing things would throw off my DVR because it would be confused about which episodes I have in relation to future airings.
