PMS/Web UI ability to embed PMS held metadata in to mp4 file
Title pretty much sum it up.
Once you are satisfied with your metadata, artwork etc it would be nice to save those data to your MP4/M4V file. In case you need to re-scan your media your library will get populated the way you want.
Batch processing would be interesting as well as the button that would pop-up on item level if item is MP4/M4V file.
I'm pretty sure there is a utility for this. Have a look in the developers section. Granted it is not built in PMS but could be made into a plugin ?!?!
here
