PMS (Windows) problems with libraries
Server Version#: 1.14.1.5488
Windows 10 x64
I suspect that I screwed up my Plex install when I replaced my system drive. I really hope someone can help me. I’ve uploaded my logs, and here are my symptoms:
When I log into the web application and press the home button, I get this:
There was an unexpected error loading the dashboard
Please visit our forums if you continue to experience problems
When I click on the “TV Shows” it works as usual, but “Movies” gives me the same error as above.
On the Windows desktop app, I get the following message on startup: Error encountered while retrieving hubs
When I click “Movies” I get:
Error downloading data from server
HTTP error code 500
But when I click on “TV Shows” I see most of my shows. That’s another part of the problem. Anything added to the library in the last 4 weeks doesn’t show up.
Plex Media Server Logs_2019-01-18_22-12-18.zip (3.1 MB)
I have the same problem but in reverse. I can access Movies but not our TV Shows. It just started with same version as yours.
It looks like I got mine working again. It seems that my sqlite database became corrupted. I’m not sure if it is related to the update. However, I was able to load one of the backup database files the plex media server creates and I’m up and running.
I followed the procedures on the link below. It looks like your logs are reporting a similar error as mine.
https://support.plex.tv/articles/202485658-restore-a-database-backed-up-via-scheduled-tasks/
I hope this helps.
