I am trying to figure out if there is a way to simply point the Plex server to the Itunes folder that I have located in my Synology Drive Client. I don’t want the server pointing at the local drive as that computer is often shutdown and I want the entire music library up 24/7 on the synology NAS.
When I browse around, I am not able to get to that directory for some reason, and when I put in the path manually, nothing seems to happen.
The idea is that whenever I update or add any music to the itunes library or playlists, the changes just transfer over to plex.
Any thoughts, or do I need to install the plugin and do this a different way.
Server Version#: 1.18.5.2309
Player Version#: 4.12.3
As for importing iTunes playlists, it’s a trip.
I tried to make it work once. Linux pathnames and Windows-based iTunes doesn’t work together (obviously). Shortly after that I deleted my remaining Windows VM.
