Pointing to imdp page
is it possible to add an input to manually point to imdp page for movies or tv shows so if there is two movies with same name we can identify the correct one.
You already can do that.
If your movie isn’t matching correctly, use Fix Match. You can enter the IMDb ID instead of the movie name – this should also work with the TMDb ID.
If you have 2 movies accidentally (wrongly) merged you need to Split the item before applying Fix Match.
From https://support.plex.tv/articles/201018497-fix-match-match/
Tips
There are a couple of neat tricks you can use to help with matching.
  • When in a Movie library, you can enter the IMDB ID in the title and search for that. For instance, the IMDB entry for “Brave” is Brave (2012) - IMDb. If you enter tt1217209 as the search term, it will search for that exact movie to try to match.
  • For a TV Shows library, you can similarly enter the TVDB ID as the title to search for that particular show. “Archer (2009) has the URL Archer (2009) - TheTVDB.com, so entering 110381 as the search term will search for that exact show.
