Port Forwarding With Century Link
Hi. My automatic mapping works for a while but then it fails and the only way to fix it is to restart the modem. So I am assuming my modem must stink so I need to manually do port forwarding as it states. But I need some help.
Century link says to do this:
http://internethelp.centurylink.com/internethelp/modem-pk5001z-adv-port-forwarding.html
Obviously my modem is a pk5001z from century link.
But I am still uncertain what numbers I need to fill in which spot for the correct Plex setup.
Can someone walk me through this?
P.S. I am sorry if these instructions are posted somewhere else. I searched and couldn't find anything.
Thanks.
Thanks.
Manually Enter IP Address: give here the local LAN IP Address of the PC running Plex Media Server. ipconfig will tell you what it is
(But you should make sure it never changes - so find out how to use dhcp reservation to set an IP Address for the MAC Hardware Physical Address)
ipconfig /all
will give you the Physical Address (MAC Address)
LAN Port Information:
Starting Port 32400
Ending Port 32400
Protocol:
TCP
Remote Port and IP Information
All IP Addresses
Apply
On the Plex Media Server myPlex settings
http://localhost:32400/web/index.html#!/settings
Show Advanced Settings
myPlex
Tick Manually Specify Port and enter 32400
Retry connection
Hi.
I followed all of the instructions that you listed, which were very clear.
However, when I hit Apply, I received the following message:
The defined port or port range is in use by another port forwarding or application rule.
Visit www.centurylink.com
When I try another port in the range suggested by PLEX (20,000 - 50,000) (I used 45000) It works. When I manually enter that port in the PLEX server config and apply, I still don’t get any remote connection available.
Please advise if I did something wrong, or if I missed something.
