Hello from Germany
I run Plex on a WD Ex2 Ultra. My ISP is Deutsche Telekom and I have a Speedport Hybrid Router
Who can point me into the right direction?
Thank you
If you have a quick search, the outside port is something like 12800 which nats to internal 32400
If you create the port forwarding manually, you must check “Öffentlichen Port manuell definieren” and put the external port number (in your case 32400) behind it. And you don’t need to forward UDP. TCP is enough.
