Server Version#: 1.28.1.6104-788f82488
ffmpeg version: 4.2.3
Solution: change rematrix_maxval from 0.000000dB to 0.
The problem should be familiar. When you play a file with 5.1 channel audio on a stereo device, the volume is too low. In my case, I’m casting from an android phone to a chromecast, using direct play. Even though video plays directly, audio still has to be transcoded if it is not already stereo AAC.
I looked through the logs while playing a video where the volume was too low, and I found the ffmpeg command performing the transcode from eac3 to mp3. This part stood out:
-map 0:0 -metadata:s:0 language=jpn -codec:0 copy -filter_complex "[0:1] aresample=async=1:ocl='stereo':rematrix_maxval=0.000000dB:osr=48000[0]"
According to the ffmpeg docs, rematrix_maxval accepts values 0 to 1 to prevent clipping vs preventing volume reduction https://ffmpeg.org/ffmpeg-resampler.html. By default the value is 1 (to prevent clipping) so the intent of the plex command is clearly to preserve volume. However, running the command outside of plex with ffmpeg produces a much quieter output than the original 5.1 input.
ffmpeg -i 1x01.ac3 -c:a libmp3lame -filter_complex "[0:0] aresample=async=1:ocl='stereo':rematrix_maxval=0.000000dB:osr=48000" 1x01.mp3
The first thing I tried was changing the rematrix_maxval to 0 (removing the dB) so that it reads:
rematrix_maxval=0
The resulting mp3 was loud, just like the original ac3 input. The volume is also maintained when transcoding to aac. Can I get a plex employee’s opinion on this? If it’s good, where can I submit the change? I looked at the plex github and there were too many repositories to make sense of.
edit: I guess plex isn’t open source
so nevermind about the last part.
edit2: I may have been a little off the mark about default values.
Running ffmpeg with defaults actually produces a normal loud mp3:
ffmpeg -i 1x01.ac3 1x01.mp3
- Running with
rematrix_maxvalat0also produces a loud mp3. -
rematrix_maxval=1produces a quiet mp3 - The original
rematrix_maxval=0.000000dBalso produces a quiet mp3
So maybe 0.000000dB is a valid argument, and the goal was audio normalization rather than volume preservation. Or maybe not, and rematrix_maxval only defaults to 1 when you pass it with a bad argument in a filter. Regardless, since the volume is about half what it should be, and there is no option for the user to change it, I think it’s better to make it loud.
