Anyone know if there is a way to create “Optimized” files but have them go to a separate library? I’ve playing around with streaming files to my GearVR but the files need to be converted to a mp4/aac container. It’s handy being able to Optimize the files but ideally I’d like to have all the compatible files in a separate library so I know which stuff is compatible.
If you specify a location for the optimized versions that is outside of the path of your normal Library folder you can then create a separte library that just looks at that optimized folder.
Version storage location
Choose where the optimized versions should be stored.
In folders with original items - A “Plex Versions” folder will be created to house the optimized version inside the folder that houses the corresponding source file.
Folder Paths - You will have an entry corresponding to the path for each library location you’ve specified for the library. The “Plex Versions” folder will then be created under the selected path.
Tip!: If you want to keep all optimized versions together in a custom location, add that location to your library by editing the library, then select it here.
