I wonder if its somehow possible to disable myPlex on RasPlex?
I choose not to use the function and everytime I stream Spotify through AirPlay or play a movie the myPlex login window appears.
Thanks in advance.
Thanks in advance.
I would like that feature too! If you do not use myplex the constant popups are a bit annoying :(
