Server Version#: 1.24.5.5160
I’m using the new agents.
This affects new entries and older entries. It seems that the searched posters and backgrounds are not cached. If I edit an entry I have to switch several times between posters and backgrounds until the online available ones are shown at all.
Seems like there is currently a problem with the agent in general. I can’t match anything and can’t find posters etc. anymore.
After some time, when trying to edit again, the first time, the poster view or the background view is empty again.
And I can’t match films, probably Plex Movie is down
Same problem here. The Plex movie agent is down.
Had thought it was related to the downtime. However, the mentioned problem still happens.
It seems that if you switch tabs too quickly, you will interrupt the request .. or if the request takes longer than usual. So if you interrupt the request /library/metadata/XXXXX/posters the request /library/metadata/XXXXX/arts will not be executed properly?
But if you wait until the posters in the poster tab are fully loaded, the backgrounds appear in the background tab the first time. This also happens the other way around.
It’s only a small issue, but it should be changed for a better user experience. Maybe a loading indicator?
Edit: Speaking of user experience. The selection is not remembered visually when you switch between tabs.
