Preferences -> Rasplex Settings?
For some reason I am just not able to find the Rasplex System Settings...
I know they were there, I know how the menu is supposed to (or at least used to) look, but I don't know where they went or when.
Under Preferences, I have the categories Appearance, Playback, System and Network. But nothing where I'd be able to configure my wireless network settings.
Am I missing something or is something wrong with my setup?
Oh yeah, I'm running 0.5.1 on an RPi 2.
EDIT: I just can't seem to rotate the images... I hope that doesn't matter :)
The OpenELEC 'System Settings' submenu is not found 'inside' the 'Preferences' menu (which is almost identical for PC PHT and RasPlex).
You should have the 'System Settings' entry at the same side menu level where you have 'Preferences', 'Control Precaching', 'Shutdown', etc.
It should be between 'Preferences' and 'Control Precaching', like this:
![post-96491-0-48218500-1427309828.jpg|690x389](upload://9miammX7ccL8dQC1TsyuyIgpCs9.jpg)
If the 'System Settings' entry is not present in your side menu, as shown above, even when you scroll through the entire menu, then something is FATALLY wrong with your install.
NB: This assumes that you are using the original 'Plex' skin. If you experiment with custom skins, then you must accept that some of those may lack menu entries specific to RasPlex or the OpenELEC system, since many of those skins were designed only for PC versions of PHT.
Hmmm: On second thought, I see that you have a 'Switch User' entry in the menu that must be specific to the new 'Plex Home' usage, meaning that your PMS server has multiple local user accounts defined. This is something I never have done and probably never will, since it radically modifies how the PMS server works. Apparently the inclusion of that entry in the menu has usurped the position normally reserved for 'System Settings'. I'm not really sure how to deal with that problem.
One thing you can try is to boot RasPlex with the network disconnected (just pull out the Ethernet cable and/or any WiFi dongle).
Since RasPlex then can't reach any server it should refrain from making any menu changes that depend on the server's 'Plex Home' usage.
Perhaps that will allow you to see the 'System Settings' entry. And then you can try reconnecting network after opening the 'System Settings' submenu.
That shouldn't matter. RPi1 and RPi2 versions of RasPlex have identical side menus (as long as it's the same RasPlex version).
Nah..., we can just tilt our heads to the left... :lol:
Best regards: dlanor
Interesting... I will try reinstalling... But I have absolutely no idea how it could have come to this...
Neither have I, but please confirm whether or not you have activated 'Plex Home' in your PMS server by definining local PMS user accounts.
By this I mean accounts defined only in your local PMS server, but not registered as accounts on the Plex.tv web pages.
Doing so does modify both how the PMS server works and how all clients connecting to it must work. (Which is the reason I don't use 'Plex Home' features myself.)
I use RPI 2 with Plex Home activated and System Settings is visible for me but only when I am signed in with the master account.
I had already reflashed the SD card before checking any login settings.
I'm pretty sure I only have plex.tv activated accounts, also after reflashing the System Settings reappeared without any changes to the servers.
Anyway, thanks for your help :)
I kn ow this is a bit late, and it may have been solved, but I have had the same issue. But I have multiple users on Plex. If I am signed in as a user, when I press the left navigation arrow twice, I get the option to switch user. If I switch to the main account holder, then press the left arrow twice, I get preferences and the option to change the audio and other items. Works very well.
