Preferred network interface does not work on Mac OS 10.14.6
Server Version#: 4.12.3
What do I input into this field? Currently the IP address does not work.
From this help URL, it doesn’t actually specify what to input into this text field. The help docs show a dropdown in the UI which I don’t see either on Safari or Chrome.
Do I input the hardware port name, device name, MAC address, IP address?
If your refering to:
The network interface local clients will use to connect.
I use my router to connect always as i use a application Exception Split Tunneling VPN solution. If you have a active VPN unlike my solution you will see a drop down menu with two interfaces .
  1. All ( if I remember correctly)
  2. Your Router/modem LAN IP
It’s just a text box for me:
I have two network interfaces unfortunately both of which connect to the internet, but it always default to the WIFI connection, rather than the thunderbolt ethernet one.
What do you use for this? The plan is to incorporate a VPN afterwards.
I use a VPN for security and Geo restricted services but it annoying to remember to turn it off for remote access. So everything except Plex go through the tunnel, Plex requires to call home, to gather metadata and plex online services. I’m satisfied that https for Plex services is sufficient.
There are a few providers of split tunneling, some are suitable, some are expensive. I use PIA, inexpensive and easy to use apps with great configuration for connection, privacy.
Your network devices have names line en0, en1. Use the thunderbolt one for preferred.
that’s the issue, it doesn’t work when I specify. It always defaults to WIFI. So I’m not sure what to input in the box, so it picks the right interface.
Are you running your server / Mac with Ethernet and WiFi live or do you connect to router WiFi.
Personally I have had only problems running both concurrently, I understand it convenient for AirDrop. There are work a rounds.
I have a multi homed server and selected the primary interface for plex to use in the settings but remote access still shows plex using one of my other interfaces for remote access.
plexlogs.tar.gz (3.2 MB)
