Hello,
Sporadic issue that can’t be reproduced on demand. I’ve been having this issue for a few months, the only reason I haven’t reported it is because I’ve been trying to find a way to get it reproducable. So far, all attempts have been failures. As far as I can tell, this problem is just completely random.
When I start playing a file (sometimes a TV show, sometimes a movie), when I click on play the display/menu with appear to “blink” for want of a better description, then return to where it was. I then hear the audio from the show, but I still see the screen you need to be at to start playing a show.
Pressing the play/pause button does just that - pauses and continues on the audio. Pressing the “menu” button usually takes you out of the video back to the screen I’m currently seeing, but when this problem happens I can go through menus and the audio from the show will keep playing. The only way to stop it is to press the “home” button and go back to the ATV’s menu. At this point I usually quit out of Plex, and re-open it. If I then go back to the exact same show, it will play normally (ie, it will not have this problem).
It seems to happen once a week or once a fortnight, though I’ve also had it happen within quick succession of happens, watch normally, happens, then won’t happen for a week or two. I have not been able to predict its ocurrence, otherwise I would have recorded video of it so I could demo it.
If there’s any more specific details you’d like me to try to provide or tests you’d like me to do, please let me know (ie, turn on logging and make sure I report timestamps of it - I’m leaving my system on default settings for now).
All my media is pre-converted to mp4 containers, h.264 video codecs and aac audio codecs. The videos this has happened to are a combination of 1080p, 720p, 480p. 20-minutes to 130-minutes in length. I have direct play enabled, but I’ve had this happen when I’ve been using direct stream too (with direct play disabled).
This has happened through multiple versions of tvOS, Plex for ATV, and Plex Media Server. My current versions at time of writing is
Plex Media Server 1.4.1.3362 (last ocurred on 1.2.0.3167 PlexDVR Beta4 - updated the server this morning but haven’t tried playing anything yet)
macOS 10.12.3
Plex for ATV 1.7 (4782)
tvOS 10.1.1
Other threads that have brought up this issue - https://forums.plex.tv/discussion/comment/1375357/ - https://forums.plex.tv/discussion/comment/1300348/
