I see in the newest update 1.0.0.11 trailers are available. I just updated but don't see where you select the trailer.
Thanks,
Thanks,
Thanks,
After you click a movie to watch, your in the screen with the large artwork and the plot and such, in the upper left corner under the play button there is a little film strip icon, that should play the trailer.
I'm missing that icon... my other devices like iphone and fire tv stick show the trailer icon.
I wonder if this works with both local and online trailers.
How do you see app version or even update for that matter? Is it Automatic?
so a couple of things:
1.) I had to do a hard reset before trailers icon would show (might have been a coincidence)
2.) Only a small percentage of movies have the trailer icon available. <- is this normal for everyone or something wrong my end?
Cheers
Cheers
I'm seeing this same result...I believe it is only showing for the "local" trailers I have. I was always curious why this feature doesn't just stream an online trailer..I haven't seen online trailers in any of my client devices (Should I be?)
Xbox One
Win 8.1
WP 8.1
IOS 8
