Server Version#: 1.28.1.6041
Player Version#: N/A
I have a TV library with 300+ shows, but for the life of me can’t figure out why Plex is not picking up Terry Pratchett’s Hogfather/Color of Magic/Going Postal/Wyrd Sisters.
Even renaming their folders to “Show {tmdb-XXXX}” yields no success, naming conventions are set up like so:
Terry Pratchett's Hogfather {tmdb-4475}
Season 1
Terry Pratchett's Hogfather - s01e01.mp4
Terry Pratchett's Hogfather - s01e02.mp4
etc
I also tried creating a copy of the above shows into a new directory & created a new library with just that directory but still nothing showed up.
That won’t work, because you cannot add the show’s folder individually to a library. You must add its parent folder instead.
So from your example above:
/TV Shows <-- add this folder to the library!
/Terry Pratchett's Hogfather {tmdb-4475}
/Season 01
Since we’re talking Linux, check access permissions.
The show’s title is just “Hogfather”. So it might have been mismatched before, which wasn’t cleared up by your eventually renaming.
So perform the Plex Dance to clear up that earlier mismatch.
(Adding the TMDB ID will also only work if your library is using the new metadata agent named “Plex TV Series”. If you are still on the old agent, remove “Terry Pratchett’s” from the folder names, then perform the Plex Dance.)
