problem adding trailers.cer into ATV3
i have problem Installing http://trailers.apple.com/trailers.cer to my ATV3. it takes long time to add profile and it said "unable to add profile (-1001)".  if anyone can help me solve this problem.
This log does show - NOTHING. We need a log where you actually used your aTV to trigger PlexConnect...
I'm confuse!?
In other words: During the time the log was captured, your aTV did NOT talk to PlexConnect.
how to make my aTV talk to plexconnect?
Change DNS? Hit Trailers?
i did change dns and hit trailers, i get this message "trailers is unavailable. try again later."
Ok. I would like to see a log from that...
How is your firewall?
1. how to get a log?
2. idk if my firewall is blocking the network.
You added a log in your first post. Same procedure - just with more content. Start PlexConnect, use your aTV, stop PlexConnect, ...
Regarding your firewall: I don't know either.
Looks good... if you now can't add the certs - try 192.168.1.5/trailers.cer - you got to work on your firewall. Python needs access through ports 80/443.
cant access through port 80.
"WebServer: Failed to connect to HTTP on 192.168.1.5 port 80: [Errno 100
13] An attempt was made to access a socket in a way forbidden by its access perm
issions"
I did enter 192.168.1.5/trailers.cer and got this message "unable to add profile. an error occurred while adding the profile [109]. check the URL and try again."
i have avg internet security 2015 and i don't know how to setup python access through ports 80/443.
From memory in that you can list Python.exe as trusted.
You can also disable the firewall(s) temporarily to find the culprit then add them back if the firewall Is even the culprit. The more you can rule out the faster you can debug :wink:
i just added trailers.cer on my atv and now trailers unavailable. try again later.
Reboot your aTV then try the hijack again. If that doesn't work provide another log as @baa informed you to prior. I assume you set your DNS to your PlexConnect Host IP address.
