Problem after changing my password
Server Version#: v1.13.6.5339-115f087d6 - FreeBSD PC amd64
After i change my password, the server start to be unavailable even on the local network. I can’t see in the log any problem but i can’t see the server in the list and i’m unable to see him for cleam or log. I can connect to the web interface on the local network. Login but i still didn’t see the plex server in the list. He is in a Jail on a freenas 11.1 U6.
Sep 09, 2018 06:50:25.924 [0x80a807000] INFO - Plex Media Server v1.13.6.5339-115f087d6 - FreeBSD PC amd64 - build: freebsd-x86_64 freebsd - GMT -07:00
Sep 09, 2018 06:50:25.927 [0x80a807000] ERROR - Failed to determine system locale: locale::facet::_S_create_c_locale name not valid. Defaulting to en-US.
Sep 09, 2018 06:50:25.927 [0x80a807000] INFO - FreeBSD version: 11.0-RELEASE (FreeBSD 11.1-STABLE #0 r321665+9902d126c39(freenas/11.1-stable): Tue Aug 21 12:24:37 EDT 2018 root@nemesis.tn.ixsystems.com:/freenas-11-releng/freenas/_BE/objs/freenas-11-releng/freenas/_BE/os/sys/FreeNAS.amd64), language: en-US
Sep 09, 2018 06:50:25.927 [0x80a807000] INFO - Processor Intel® Xeon® CPU E5-2630 v4 @ 2.20GHz
Sep 09, 2018 06:50:25.927 [0x80a807000] INFO - /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server
Sep 09, 2018 06:50:25.791 [0x80a806400] WARN - Default locale is invalid; falling back on classic+UTF-8
Sep 09, 2018 06:50:25.922 [0x80a806400] DEBUG - BPQ: [Idle] -> [Starting]
Sep 09, 2018 06:50:25.927 [0x80a806400] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.13.0, threadsafe=1
Sep 09, 2018 06:50:25.953 [0x80a806400] INFO - SQLITE3:0x10, 283, recovered 829 frames from WAL file /var/db/plexdata/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Sep 09, 2018 06:50:26.066 [0x80a806400] DEBUG - Running migrations. (EPG 0)
Sep 09, 2018 06:50:26.562 [0x80a806400] DEBUG - ChangestampAllocator: initialized to 8746394
Sep 09, 2018 06:50:26.562 [0x80a806400] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.13.0, threadsafe=1
Sep 09, 2018 06:50:26.568 [0x80a806400] INFO - SQLITE3:0x10, 283, recovered 185 frames from WAL file /var/db/plexdata/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal
Sep 09, 2018 06:50:26.578 [0x80a806400] DEBUG - Running migrations. (EPG 0)
Sep 09, 2018 06:50:26.605 [0x80a806400] DEBUG - HttpServer: Listening on port 32400 with queue of 128 connections.
Sep 09, 2018 06:50:26.606 [0x80a806400] DEBUG - HttpServer: Listening on port 32401 with queue of 128 connections.
Sep 09, 2018 06:50:26.622 [0x80d026400] DEBUG - DVR:Grabber: Cleaning up orphaned grabs.
Sep 09, 2018 06:50:26.624 [0x80a806400] DEBUG - Media Provider: Registering provider com.plexapp.plugins.library
Sep 09, 2018 06:50:26.624 [0x80a806400] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Sep 09, 2018 06:50:26.626 [0x80d027400] DEBUG - Relay: read 32 cached entries from hosts file
Sep 09, 2018 06:50:26.626 [0x80a806400] DEBUG - Relay: read 32 cached entries from hosts file
Sep 09, 2018 06:50:26.627 [0x80d027400] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=
Sep 09, 2018 06:50:26.628 [0x80d026c00] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Sep 09, 2018 06:50:26.632 [0x80d027800] DEBUG - File “/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Plug-ins-115f087d6” changed: -1 => 1534778645.
Sep 09, 2018 06:50:26.632 [0x80d027800] DEBUG - File “/var/db/plexdata/Plex Media Server/Plug-ins” changed: -1 => 1533933149.
Sep 09, 2018 06:50:26.632 [0x80d027800] DEBUG - Scanning for plug-ins in “/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Plug-ins-115f087d6”
Sep 09, 2018 06:50:26.647 [0x80d027800] DEBUG - Scanning for plug-ins in “/var/db/plexdata/Plex Media Server/Plug-ins”
Sep 09, 2018 06:50:26.651 [0x80d027800] DEBUG - PluginRepository::setStartState: 1, startingSystem
Sep 09, 2018 06:50:26.651 [0x80d027800] DEBUG - Starting plug-in /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Plug-ins-115f087d6/System.bundle.
Sep 09, 2018 06:50:26.652 [0x80d027800] DEBUG - [com.plexapp.system] Setting plug-in to always running (daemon mode).
Sep 09, 2018 06:50:26.653 [0x80d027800] DEBUG - Starting file watcher for com.plexapp.system
Sep 09, 2018 06:50:26.654 [0x80d027800] DEBUG - Plugin: not setting user token for plugin
Sep 09, 2018 06:50:26.656 [0x80d027800] DEBUG - Spawned plug-in com.plexapp.system with PID 8191
Sep 09, 2018 06:50:26.657 [0x80d027800] DEBUG - [com.plexapp.system] Sending command: GET /:/prefixes
Sep 09, 2018 06:50:26.733 [0x80d027400] DEBUG - HTTP 401 response from GET https://plex.tv/media/providers?X-Plex-Token=
Sep 09, 2018 06:50:27.287 [0x80d026400] DEBUG - DVR:Grabber: Cleaned up 0 decrepit directories in 0.1 sec.
Sep 09, 2018 06:50:29.485 [0x80d027800] DEBUG - Reading 486 bytes in the body, code is 200
Sep 09, 2018 06:50:29.485 [0x80d027800] DEBUG - [com.plexapp.system] Plug-in running on port 25154.
Sep 09, 2018 06:50:29.485 [0x80d027800] DEBUG - * Plug-in handles prefix: /system
Sep 09, 2018 06:50:29.485 [0x80d027800] DEBUG - * Plug-in handles prefix: /player
Sep 09, 2018 06:50:29.485 [0x80d027800] DEBUG - Read configuration for [com.plexapp.system], had 2 prefixes
Sep 09, 2018 06:50:29.486 [0x80d027800] DEBUG - Done with 1 synchronous plug-in starts, starting the rest in parallel.
Sep 09, 2018 06:50:29.486 [0x80d027800] DEBUG - PluginRepository::setStartState: 2, startingPlugins
Sep 09, 2018 06:50:29.486 [0x80d027800] DEBUG - Updating the list of agents known by the system.
Sep 09, 2018 06:50:29.486 [0x80d027800] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/agents
Sep 09, 2018 06:50:29.486 [0x80d027800] DEBUG - HTTP requesting GET http://127.0.0.1:25154/system/agents
Sep 09, 2018 06:50:29.486 [0x80a806400] DEBUG - Image transcode cache directory: “/var/db/plexdata/Plex Media Server/Cache/PhotoTranscoder”
Sep 09, 2018 06:50:29.487 [0x80a806400] DEBUG - Transcoder: Cleaning old transcode directories.
Sep 09, 2018 06:50:29.488 [0x80a806400] DEBUG - PublicAddressManager: Starting.
Sep 09, 2018 06:50:29.488 [0x80a806400] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Sep 09, 2018 06:50:29.488 [0x80a806400] DEBUG - NetworkInterface: Starting watch thread.
Sep 09, 2018 06:50:29.489 [0x80d027400] DEBUG - NAT: UPnP, attempting port mapping.
Sep 09, 2018 06:50:29.489 [0x80d026400] DEBUG - PublicAddressManager: Obtaining public IP.
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - Network change.
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 09, 2018 06:50:29.489 [0x80d026400] DEBUG - HTTP requesting GET http://plex.tv/pms/:/ip
Sep 09, 2018 06:50:29.489 [0x80d028400] DEBUG - NetworkInterface: Watching for changes on the interfaces.
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - Network interfaces:
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - * 1 lo0 (127.0.0.1) (loopback: 1)
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - * 2 epair0b (192.168.1.202) (loopback: 0)
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - Creating NetworkServices singleton.
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - NetworkServices: Initializing…
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - NetworkService: Creating new service.
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - NetworkService: Got notification of changed network (first change: 1)
Sep 09, 2018 06:50:29.489 [0x80a806400] DEBUG - NetworkService: Quick dispatch of network change.
Sep 09, 2018 06:50:29.489 [0x80d028800] DEBUG - Network change for advertiser.
Sep 09, 2018 06:50:29.489 [0x80d028800] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32414 (outbound: 0)
Sep 09, 2018 06:50:29.491 [0x80a806400] DEBUG - Starting HTTP server.
Sep 09, 2018 06:50:29.491 [0x80a806400] DEBUG - Running server…
Sep 09, 2018 06:50:29.491 [0x80a806400] DEBUG - Waiting for server condition to be signaled.
Sep 09, 2018 06:50:29.491 [0x80d028c00] DEBUG - Plex Tuner Service starting.
Sep 09, 2018 06:50:29.491 [0x80d028c00] DEBUG - Job running: ‘/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex Tuner Service’ ‘/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Tuner/Private’ ‘/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Tuner/Shared’ ‘1.13.6.5339-115f087d6’ ‘32600’ ‘/waitmutex’
Sep 09, 2018 06:50:29.491 [0x80d029000] DEBUG - HttpServer: Set up a thread pool with 2 threads.
Sep 09, 2018 06:50:29.493 [0x80d028c00] DEBUG - Jobs: Starting child process with pid 9225
Sep 09, 2018 06:50:29.494 [0x80d029000] DEBUG - HTTP requesting GET https://plex.tv/api/v2/features?X-Plex-Token=
Sep 09, 2018 06:50:29.494 [0x80d028400] DEBUG - NetworkInterface: PF_ROUTE socket received message. Version 5, Type 0xf, Len 144.
Sep 09, 2018 06:50:29.494 [0x80d028800] DEBUG - Network change for advertiser.
Sep 09, 2018 06:50:29.494 [0x80d028800] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32410 (outbound: 0)
Sep 09, 2018 06:50:29.494 [0x80d028800] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32412 (outbound: 0)
Sep 09, 2018 06:50:29.494 [0x80d028800] DEBUG - NetworkService: Network change for browser (polled=0), closing 0 browse sockets.
Sep 09, 2018 06:50:29.494 [0x80d028800] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32413 (outbound: 0)
Sep 09, 2018 06:50:29.495 [0x80d028800] DEBUG - NetworkService: Browsing on interface 192.168.1.202 on broadcast address 192.168.1.255 (index: 0)
Sep 09, 2018 06:50:29.495 [0x80d028800] DEBUG - NetworkService: Network change for browser (polled=1), closing 0 browse sockets.
Sep 09, 2018 06:50:29.495 [0x80d028800] DEBUG - NetworkService: Network change for browser (polled=0), closing 0 browse sockets.
Sep 09, 2018 06:50:29.495 [0x80d028800] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:1901 (outbound: 0)
Sep 09, 2018 06:50:29.495 [0x80d028800] DEBUG - NetworkService: Browsing on interface 192.168.1.202 on broadcast address 239.255.255.250 (index: 0)
Sep 09, 2018 06:50:29.497 [0x8118c1400] DEBUG - Request: [127.0.0.1:23120 (Loopback)] GET / (6 live) GZIP
