Hi to all,
i would like to know if there is some trick to view big size’s image to plex.
I have some tiffs photos where the size is more than 100 mb (because is some shoot with reflex camera) and i whant keep it as original … but i would like to see them in plex!
I can see correctly the thumbnail but if i click on it, i can’t see the image (in every client) (if i remember good, it say : unable to load photo).
I can of course see the image information and i can download correctly (so the image link is ok).
If i understand from others posts, there is some limitation for view image bigger than 100mb, but maybe this problem is near to be fixed or maybe there is some trick for watch the image (without modify the file)?
PMS is installed in a custom nas running OMV (Open Media Vault).
PMS is the last version and is running in Docker (whit all parameters for use successifully the transcode feature).
Hardware is not very aggressive but i think is normal for this playback:
Asrock J3455-ITX (CPU quad-core J3455, video Intel HD Graphics 500, Ram 8gb )
So, for use with plex without other software, is impossible?
