First post here, hopefully it’s not long on extraneous detail and short on relevant detail… I’m really looking forward to getting Plex dialed in here. Someday I envision using the webhooks feature to tie into an automation system. But one step at a time.
I would like to use Plex for my Blu-ray backups. I’m basically a new user although I tried Plex about 7 years ago but opted instead to use my Oppo Blu Ray player to play the .mkv files over the network. Now I’m revisiting Plex and getting it all configured. I like it but I’m having trouble with playback on my Roku devices when I select “original” quality in the Roku Plex app. Is there some setting that I need to change in either the server or on the Roku to have “original” quality work reliably? I searched but didn’t see anyone with post a similar issue.
Since I’m setting everything up for the first time, I believe everything is on the latest version (see details at end of post). Everything is local.
Note that I have the Windows client working great and have it successfully passing dts audio to my receiver (yes, I read the article about audio passthrough and I do want the “pretty light” to turn on, at least for now to know that I’m really getting the original quality file that I would view on the Oppo). The problems I describe below are unique to the Roku and are not present on the PC client.
I am trying out a new Roku Premiere as I’m really just looking for something that can play my Blu-ray backups in the original quality and want an easier “couch” interface than the PC client.
I have the following problems when I select “original” for Roku settings video – local quality:
The strangest problem to me is when playing Finding Nemo or Finding Dory. The Roku loads the video, plays for a couple minutes, stops and then shows the video in the “recently played”. If I try to resume, Plex shows the “recently played” screen immediately. This is very reproducible. Perhaps not surprisingly, if I have local quality as “original” but direct play “disabled” it seems to play fine.
I can get Finding Nemo/Dory to play fine when the video setting is 20Mbps 4K and when direct play is set to “auto”. As I would expect, even if I have 20Mbps / 4K selected in the Roku Plex app, if I have direct play set to “force” I have the same problem. Note this problem also happens on “original” whether I have direct play set to force or Auto.
While trying to play “Ford vs. Ferrari” in original quality, after about 4 minutes I get – “Playback error - your connected to the server was not fast enough to stream this video. Check your network or try a lower quality”. It will show the % buffering circle sometimes and then give that message. I’ve tested a few others, including Pirates of the Caribbean and Harry Potter and they have similar problems.
Oddly, I don’t get this network speed error on 20mbps 4K so I don’t think it’s really my WiFi speed. To me all signs are pointing to some problem with the “original” quality setting on the Roku.
I doubt my WiFi is the issue as it has close line of site to a wireless access point. Roku is getting 28Mbps from the internet but signal strength is very good and I suspect LAN speeds are higher but not sure how to test that directly with the Roku. I have very few devices on WiFi as I’ve hardwired 100% of everything that has an ethernet port. That said if given that this a 2.4ghz only device it may be forced into a lower speed if there are other legacy 2ghz devices connected to that AP. But again, since this doesn’t happen on 20Mbps 4K I don’t believe it’s really the WiFi speed.
Coincidentally I was having similar problems on an inexpensive HiSense TV with Roku built in. I read here that maybe that app isn’t fully supported so I figured I’d just find another client for it. But now I went back to try and I can get 20Mbps 4K to work fine here too.
I’ve enabled debugging logging. If logs are needed which ones should I post? I’m a bit concerned that there could be some private info in there somewhere…
Roku is updated as of this morning. Software 9.4.0 build 4200-91
Roku Plex version appears to be 6.7.9.6822-21
Server version 4.51.1 (or is it Version 1.21.3.4046)
Player version 1.28.0.1681-cc6e807c for Windows
Server –
HP Elite 8300
Windows 10 Pro 64-Bit
Intel Quad Core i7-3770s Processor 3.1 GHz, 8MB cache
8 GB DDR3 SODIMM
240 GB Solid State hard drive
Intel HD Graphics 2500
Integrated high definition audio
