Problem streaming 4k video only outside LAN network
Server Version#: 1.30.0.6442
Player Version#: 8.33 for Apple iOS
I’m running PLEX locally on my QNAP on my home network (I think I can’t update plex myself on QNAP?!), I use plex media server every day in LAN and all works fine.
The only problem I have is when I try to do streaming of a 4K video and plex client is ouside LAN network (in WAN connected to internet): video streaming stop often and it’s not possibile to have a good playback.
I tried to play a version with lower resolution, but it seems not solving my issue…
any ideas?
Do a speed test on your internet. Most ISPs limit the upload speeds which are not fast enough for 4k.
i have VDSL VODAFONE.
My Speedtest say always 30Mbps in UPLOAD: it’s not sufficient for 4K streaming?
No you can do 20 mbit 1080 but you may want to select a bit lower bit rate to give some head room.
