Problem when using XTEVE and EPG
Server Version#: 1.22.1.4228
Player Version#: WEB
Tuner Make/Model: XTEVE
Guide/Lineup name: /
Using XMLTV?: own xml
Channel number/Name: 10
Hey Guys, i tried to add my own IPTV Playlist.
also created a playlist and mapped some channels
filled in the xml URL.
when i want to add it in plex it only let me the options to catch the epg from my local cable provider.
it doesnt give me the option to fill out my own xml url.
You need to start the DVR set up from scratch and then on that screen where it tells you to set your city, at the very top you will see a link to enter XMLTV file/location.
If you have an existing tuner already set up, then for xTeve it will ALWAYS use the existing EPG from the existing tuner. Plex can only handle one EPG. The workaround for this is to start from scratch, open two tabs and redo the set ups for each DVR.
