Problem with audio snapping on Plex Arcade
Hi, I have a problem with the Plex Arcade. Virtually every time I start a game, I have problems with the sound that clicks. I attach the logs file. Thanks anyone who can help me.
Jan 02, 2022 17:54:16.961 [0x00003b4c] DEBUG - Starting up with core: D:\Plex-Data\Plex Media Server\Game Cores\mame_libretro.dll and game: D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip platform: Arcade.
Jan 02, 2022 17:54:16.965 [0x00003b4c] DEBUG - Parsec: hostname      = MEDIACENTER
Jan 02, 2022 17:54:16.965 [0x00003b4c] DEBUG - Parsec: ctrl_support  = 0
Jan 02, 2022 17:54:18.158 [0x00003b4c] INFO - SYSTEM_DIRECTORY: D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1
Jan 02, 2022 17:54:18.158 [0x00003b4c] WARNING - Retro: Unhandled env #30
Jan 02, 2022 17:54:18.158 [0x00003b4c] INFO - CONTENT_DIRECTORY: (null)
Jan 02, 2022 17:54:18.158 [0x00003b4c] DEBUG - Retro: Asked for save directory.
Jan 02, 2022 17:54:18.158 [0x00003b4c] INFO - SAVE_DIRECTORY: D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1
Jan 02, 2022 17:54:18.158 [0x00003b4c] DEBUG - Setting pixel format to BGRA8888.
Jan 02, 2022 17:54:18.165 [0x00003b4c] INFO - Joystick map: disabled
Jan 02, 2022 17:54:18.193 [0x00003b4c] INFO - Joystick map: disabled
Jan 02, 2022 17:54:18.193 [0x00003b4c] INFO - AV_INFO: width=640 height=480
Jan 02, 2022 17:54:18.193 [0x00003b4c] INFO - AV_INFO: max_width=640 max_height=480
Jan 02, 2022 17:54:18.193 [0x00003b4c] INFO - AV_INFO: aspect_ratio = 1.333333
Jan 02, 2022 17:54:18.194 [0x00003b4c] INFO - AV_INFO: fps = 60.000000 sample_rate = 48000.000000
Jan 02, 2022 17:54:18.194 [0x00003b4c] INFO - FPS reported as 60.000000.
Jan 02, 2022 17:54:18.418 [0x00003b4c] DEBUG - OpenGL: Creating a context for OpenGL v3.
Jan 02, 2022 17:54:18.432 [0x00003b4c] DEBUG - GL Vendor graphic card: NVIDIA Corporation
Jan 02, 2022 17:54:18.432 [0x00003b4c] DEBUG - GL Version: 3.1.0 NVIDIA 497.29
Jan 02, 2022 17:54:18.432 [0x00003b4c] DEBUG - GL Renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
Jan 02, 2022 17:54:18.432 [0x00003b4c] DEBUG - GL Shading language version: 1.40 NVIDIA via Cg compiler
Jan 02, 2022 17:54:18.451 [0x00003b4c] DEBUG - Initializing texture and framebuffer to 640 x 480.
Jan 02, 2022 17:54:18.459 [0x00003b4c] DEBUG - Renderer: Raw aspect ratio is 1.333, desired aspect ratio is 1.333, resolution computed is 640 x 480.
Jan 02, 2022 17:54:18.459 [0x00003b4c] DEBUG - Computed scale factor 2.25 for display size 1920 x 1080.
Jan 02, 2022 17:54:18.459 [0x00003b4c] DEBUG - Using encoder scale factor 2x, encode size: 1920 x 1080.
Jan 02, 2022 17:54:18.460 [0x00003b4c] INFO - OpenGL: Refreshing vertex data with resolution 640 x 480 (frames: 0 x 0).
Jan 02, 2022 17:54:18.460 [0x00003b4c] DEBUG - OpenGL: Using scale factor 1.0 x 1.0.
Jan 02, 2022 17:54:18.461 [0x00003b4c] INFO - Parsec: Encoding with FPS of 60.
Jan 02, 2022 17:54:18.461 [0x00003b4c] DEBUG - FPS = 60.000000, microseconds per frame: 16666.
Jan 02, 2022 17:54:18.463 [0x00003b4c] INFO - Starting game:D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:18.463 [0x00003b4c] DEBUG - Path extraction result: File name=D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:18.463 [0x00003b4c] DEBUG - Path extraction result: Game name=mslug
Jan 02, 2022 17:54:18.463 [0x00003b4c] DEBUG - Path extraction result: System name=Arcade
Jan 02, 2022 17:54:18.463 [0x00003b4c] DEBUG - Path extraction result: Game path=D:\Plex-Data\Plex Media Server\Games\Arcade
Jan 02, 2022 17:54:18.463 [0x00003b4c] DEBUG - Path extraction result: Parent path=D:\Plex-Data\Plex Media Server\Games
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG - Searching for driver mslug
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG - System type: ARCADE
Jan 02, 2022 17:54:18.464 [0x00003b4c] INFO - Game name: mslug, Game description: Metal Slug - Super Vehicle-001
Jan 02, 2022 17:54:18.464 [0x00003b4c] ERROR - System not found: Arcade
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG - Searching for driver Arcade
Jan 02, 2022 17:54:18.464 [0x00003b4c] WARNING - Driver Arcade not found -1
Jan 02, 2022 17:54:18.464 [0x00003b4c] INFO - Creating frontend for game: mslug
Jan 02, 2022 17:54:18.464 [0x00003b4c] INFO - Softlists: 1
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG - Parameters:
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  mame
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -nothrottle
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -joystick
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -joystick_deadzone
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  0
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -joystick_saturation
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  1
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -samplerate
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  48000
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -nocheat
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -nomouse
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -nolightgun
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -noreadconfig
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -statename
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  %g/mslug
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -cfg_directory
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\cfg
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -nvram_directory
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\nvram
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -input_directory
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\input
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -state_directory
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\states
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -snapshot_directory
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\snaps
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -diff_directory
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\diff
Jan 02, 2022 17:54:18.464 [0x00003b4c] DEBUG -  -samplepath
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\samples
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  -artpath
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\artwork
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  -cheatpath
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\cheat
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  -inipath
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\ini
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  -hashpath
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\mame\hash
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  -rompath
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  D:\Plex-Data\Plex Media Server\Games\Arcade
Jan 02, 2022 17:54:18.465 [0x00003b4c] DEBUG -  mslug
Jan 02, 2022 17:54:18.467 [0x00003b4c] DEBUG - ===> registered module none uifontprovider
Jan 02, 2022 17:54:18.468 [0x00003b4c] DEBUG - ===> registered module retro sound
Jan 02, 2022 17:54:18.468 [0x00003b4c] DEBUG - ===> registered module none sound
Jan 02, 2022 17:54:18.468 [0x00003b4c] DEBUG - ===> registered module retro monitorprovider
Jan 02, 2022 17:54:18.468 [0x00003b4c] DEBUG - ===> registered module none debugger
Jan 02, 2022 17:54:18.469 [0x00003b4c] DEBUG - ===> registered module none netdevprovider
Jan 02, 2022 17:54:18.469 [0x00003b4c] DEBUG - ===> registered module pm midiprovider
Jan 02, 2022 17:54:18.469 [0x00003b4c] DEBUG - ===> registered module retro keyboardprovider
Jan 02, 2022 17:54:18.469 [0x00003b4c] DEBUG - ===> registered module none keyboardprovider
Jan 02, 2022 17:54:18.469 [0x00003b4c] DEBUG - ===> registered module retro mouseprovider
Jan 02, 2022 17:54:18.469 [0x00003b4c] DEBUG - ===> registered module none mouseprovider
Jan 02, 2022 17:54:18.469 [0x00003b4c] DEBUG - ===> registered module retro lightgunprovider
Jan 02, 2022 17:54:18.469 [0x00003b4c] DEBUG - ===> registered module none lightgunprovider
Jan 02, 2022 17:54:18.469 [0x00003b4c] DEBUG - ===> registered module retro joystickprovider
Jan 02, 2022 17:54:18.470 [0x00003b4c] DEBUG - ===> registered module none joystickprovider
Jan 02, 2022 17:54:18.470 [0x00003b4c] DEBUG - ===> registered module none output
Jan 02, 2022 17:54:18.470 [0x00003b4c] DEBUG - ===> registered module console output
Jan 02, 2022 17:54:18.470 [0x00003b4c] DEBUG - ===> registered module network output
Jan 02, 2022 17:54:19.079 [0x00003b4c] DEBUG - Enter init_monitors
Jan 02, 2022 17:54:19.079 [0x00003b4c] DEBUG - Adding monitor screen0 (640 x 480)
Jan 02, 2022 17:54:19.081 [0x00003b4c] DEBUG - Leave init_monitors
Jan 02, 2022 17:54:19.081 [0x00003b4c] WARNING - Invalid video value opengl; reverting to software
Jan 02, 2022 17:54:19.081 [0x00003b4c] DEBUG - Enter sdlwindow_init
Jan 02, 2022 17:54:19.081 [0x00003b4c] DEBUG - Leave sdlwindow_init
Jan 02, 2022 17:54:19.085 [0x00003b4c] DEBUG - Enter sdl_info::create
Jan 02, 2022 17:54:19.087 [0x00003b4c] DEBUG - Input: Adding keyboard #0: Retro Keyboard 1 (device id: Retro Keyboard 1)
Jan 02, 2022 17:54:19.087 [0x00003b4c] INFO - SOURCE FILE: ../../../../../src/mame/drivers/neogeo.cpp
Jan 02, 2022 17:54:19.087 [0x00003b4c] INFO - PARENT: neogeo
Jan 02, 2022 17:54:19.087 [0x00003b4c] INFO - NAME: mslug
Jan 02, 2022 17:54:19.087 [0x00003b4c] INFO - DESCRIPTION: Metal Slug - Super Vehicle-001
Jan 02, 2022 17:54:19.087 [0x00003b4c] INFO - YEAR: 1996
Jan 02, 2022 17:54:19.087 [0x00003b4c] INFO - MANUFACTURER: Nazca
Jan 02, 2022 17:54:19.087 [0x00003b4c] DEBUG - Input: Adding joystick #0: RetroPad0 (device id: RetroPad0)
Jan 02, 2022 17:54:19.087 [0x00003b4c] DEBUG - Input: Adding joystick #1: RetroPad1 (device id: RetroPad1)
Jan 02, 2022 17:54:19.087 [0x00003b4c] DEBUG - Input: Adding joystick #2: RetroPad2 (device id: RetroPad2)
Jan 02, 2022 17:54:19.087 [0x00003b4c] DEBUG - Input: Adding joystick #3: RetroPad3 (device id: RetroPad3)
Jan 02, 2022 17:54:19.087 [0x00003b4c] DEBUG - Input: Adding joystick #4: RetroPad4 (device id: RetroPad4)
Jan 02, 2022 17:54:19.087 [0x00003b4c] DEBUG - Input: Adding joystick #5: RetroPad5 (device id: RetroPad5)
Jan 02, 2022 17:54:19.095 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:19.095 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip ECD
Jan 02, 2022 17:54:19.095 [0x00003b4c] DEBUG - unzip: D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip has no ZIP64 ECD locator
Jan 02, 2022 17:54:19.095 [0x00003b4c] DEBUG - unzip: read D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip central directory
Jan 02, 2022 17:54:19.101 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.113 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.113 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:19.114 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.114 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.120 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip
Jan 02, 2022 17:54:19.120 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip ECD
Jan 02, 2022 17:54:19.120 [0x00003b4c] DEBUG - unzip: D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip has no ZIP64 ECD locator
Jan 02, 2022 17:54:19.120 [0x00003b4c] DEBUG - unzip: read D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip central directory
Jan 02, 2022 17:54:19.121 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip and sending to cache
Jan 02, 2022 17:54:19.122 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.122 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.122 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip in cache
Jan 02, 2022 17:54:19.122 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip
Jan 02, 2022 17:54:19.122 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip and sending to cache
Jan 02, 2022 17:54:19.123 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.123 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.124 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip in cache
Jan 02, 2022 17:54:19.124 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip
Jan 02, 2022 17:54:19.124 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip and sending to cache
Jan 02, 2022 17:54:19.125 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.125 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.125 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip in cache
Jan 02, 2022 17:54:19.125 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip
Jan 02, 2022 17:54:19.126 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\neogeo.zip and sending to cache
Jan 02, 2022 17:54:19.127 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.127 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:19.127 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.129 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.130 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:19.139 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.161 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.162 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:19.171 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.211 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.212 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:19.213 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.236 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.237 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:19.238 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.263 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.264 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:19.274 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.303 [0x00003b4c] DEBUG - unzip: found D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip in cache
Jan 02, 2022 17:54:19.304 [0x00003b4c] DEBUG - unzip: opened archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip
Jan 02, 2022 17:54:19.313 [0x00003b4c] DEBUG - unzip: closing archive file D:\Plex-Data\Plex Media Server\Games\Arcade\mslug.zip and sending to cache
Jan 02, 2022 17:54:19.660 [0x00003ba0] DEBUG - Parsec: net           = SCTP|::ffff:192.168.1.13|56837
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional device ':cslot6' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional device ':cslot5' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional device ':cslot4' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional device ':cslot3' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional device ':cslot2' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':audiocpu' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':fixed' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':sprites' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional shared pointer ':maincpu' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':maincpu' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':screen' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':ymsnd:adpcmb' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':ymsnd:adpcma' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':saveram' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':cslot1:ymsnd:adpcmb' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Optional memory region ':cslot1:audiocrypt' not found
Jan 02, 2022 17:54:19.759 [0x00003b4c] DEBUG - Starting Metal Slug - Super Vehicle-001 ':'
Jan 02, 2022 17:54:19.764 [0x00003b4c] DEBUG -   (missing dependencies; rescheduling)
Jan 02, 2022 17:54:19.764 [0x00003b4c] DEBUG - Starting Motorola MC68000 ':maincpu'
Jan 02, 2022 17:54:19.766 [0x00003b4c] DEBUG - Starting Zilog Z80 ':audiocpu'
Jan 02, 2022 17:54:19.768 [0x00003b4c] DEBUG - Starting 74HC259 Addressable Latch ':systemlatch'
Jan 02, 2022 17:54:19.768 [0x00003b4c] DEBUG - Starting Video Screen ':screen'
Jan 02, 2022 17:54:19.768 [0x00003b4c] DEBUG - Starting palette ':palette'
Jan 02, 2022 17:54:19.769 [0x00003b4c] DEBUG - Starting Neo-Geo Sprites (optimized) ':spritegen'
Jan 02, 2022 17:54:19.769 [0x00003b4c] DEBUG - Starting Input Merger (all high) ':audionmi'
Jan 02, 2022 17:54:19.769 [0x00003b4c] DEBUG - Starting Generic 8-bit latch ':soundlatch'
Jan 02, 2022 17:54:19.770 [0x00003b4c] DEBUG - Starting Generic 8-bit latch ':soundlatch2'
Jan 02, 2022 17:54:19.770 [0x00003b4c] DEBUG - Starting YM2610 OPNB ':ymsnd'
Jan 02, 2022 17:54:19.771 [0x00003b4c] DEBUG - Starting Watchdog Timer ':watchdog'
Jan 02, 2022 17:54:19.771 [0x00003b4c] DEBUG - Starting uPD4990A RTC ':upd4990a'
Jan 02, 2022 17:54:19.771 [0x00003b4c] DEBUG - Starting NVRAM ':saveram'
Jan 02, 2022 17:54:19.771 [0x00003b4c] DEBUG - Starting Speaker ':lspeaker'
Jan 02, 2022 17:54:19.772 [0x00003b4c] DEBUG - Starting Speaker ':rspeaker'
Jan 02, 2022 17:54:19.772 [0x00003b4c] DEBUG - Starting NeoGeo Memory Card ':memcard'
Jan 02, 2022 17:54:19.772 [0x00003b4c] DEBUG - Starting SNK Neo Geo Edge Connector (Controller) ':edge'
Jan 02, 2022 17:54:19.772 [0x00003b4c] DEBUG - Starting SNK Neo Geo Arcade Joystick ':edge:joy'
Jan 02, 2022 17:54:19.772 [0x00003b4c] DEBUG - Starting SNK Neo Geo controller port ':ctrl1'
Jan 02, 2022 17:54:19.772 [0x00003b4c] DEBUG - Starting SNK Neo Geo controller port ':ctrl2'
Jan 02, 2022 17:54:19.772 [0x00003b4c] DEBUG - Starting Neo Geo Cartridge Slot ':cslot1'
Jan 02, 2022 17:54:19.772 [0x00003b4c] DEBUG - Starting Neo Geo Standard Carts ':cslot1:rom'
Jan 02, 2022 17:54:19.772 [0x00003b4c] DEBUG - Starting Metal Slug - Super Vehicle-001 ':'
Jan 02, 2022 17:54:19.823 [0x00003b4c] DEBUG - Attempting to parse: default.cfg
Jan 02, 2022 17:54:19.824 [0x00003b4c] DEBUG - Attempting to parse: mslug.cfg
Jan 02, 2022 17:54:19.865 [0x00003b4c] INFO - RES:0
Jan 02, 2022 17:54:19.865 [0x00003b4c] INFO - MAIN FIRST
Jan 02, 2022 17:54:19.874 [0x00003b4c] INFO - Joystick map: disabled
Jan 02, 2022 17:54:19.874 [0x00003b4c] INFO - AV_INFO: width=320 height=224
Jan 02, 2022 17:54:19.874 [0x00003b4c] INFO - AV_INFO: max_width=320 max_height=224
Jan 02, 2022 17:54:19.874 [0x00003b4c] INFO - AV_INFO: aspect_ratio = 1.333333
Jan 02, 2022 17:54:19.874 [0x00003b4c] INFO - AV_INFO: fps = 59.185608 sample_rate = 48000.000000
Jan 02, 2022 17:54:19.874 [0x00003b4c] DEBUG - Initializing texture and framebuffer to 320 x 224.
Jan 02, 2022 17:54:19.874 [0x00003b4c] DEBUG - Renderer: Raw aspect ratio is 1.429, desired aspect ratio is 1.333, resolution computed is 320 x 240.
Jan 02, 2022 17:54:19.875 [0x00003b4c] DEBUG - Computed scale factor 4.50 for display size 1920 x 1080.
Jan 02, 2022 17:54:19.875 [0x00003b4c] DEBUG - Using encoder scale factor 5x, encode size: 1920 x 1080.
Jan 02, 2022 17:54:19.875 [0x00003b4c] INFO - OpenGL: Refreshing vertex data with resolution 320 x 224 (frames: 0 x 0).
Jan 02, 2022 17:54:19.875 [0x00003b4c] DEBUG - OpenGL: Using scale factor 1.0 x 1.0.
Jan 02, 2022 17:54:19.875 [0x00003b4c] INFO - Parsec: Encoding with FPS of 59.
Jan 02, 2022 17:54:19.875 [0x00003b4c] INFO - ChangeAV: w:320 h:224 ra:1.333333.
Jan 02, 2022 17:54:19.875 [0x00003b4c] DEBUG - Initializing texture and framebuffer to 320 x 224.
Jan 02, 2022 17:54:19.876 [0x00003b4c] DEBUG - Renderer: Raw aspect ratio is 1.429, desired aspect ratio is 1.333, resolution computed is 320 x 240.
Jan 02, 2022 17:54:19.877 [0x00003b4c] DEBUG - Computed scale factor 4.50 for display size 1920 x 1080.
Jan 02, 2022 17:54:19.877 [0x00003b4c] DEBUG - Using encoder scale factor 5x, encode size: 1920 x 1080.
Jan 02, 2022 17:54:19.877 [0x00003b4c] INFO - OpenGL: Refreshing vertex data with resolution 320 x 224 (frames: 320 x 224).
Jan 02, 2022 17:54:19.877 [0x00003b4c] DEBUG - OpenGL: Using scale factor 1.0 x 1.0.
Jan 02, 2022 17:54:19.962 [0x00003b4c] DEBUG - Custom message: 2
Jan 02, 2022 17:54:20.013 [0x00003b94] DEBUG - Parsec: encoder       = nvidia
Jan 02, 2022 17:54:20.013 [0x00003b94] DEBUG - Parsec: codec         = h264
Jan 02, 2022 17:54:20.013 [0x00003b94] DEBUG - Parsec: encode_x      = 1600
Jan 02, 2022 17:54:20.013 [0x00003b94] DEBUG - Parsec: encode_y      = 1200
Jan 02, 2022 17:54:21.694 [0x00003b94] DEBUG - Parsec: [0] FPS:57.7/91, L:3.1/72.2, B:4.3/10.0, N:0/0/0
Jan 02, 2022 17:54:23.386 [0x00003b94] DEBUG - Parsec: [0] FPS:59.1/0, L:2.4/5.3, B:1.5/10.0, N:0/0/0
Jan 02, 2022 17:54:25.076 [0x00003b94] DEBUG - Parsec: [0] FPS:59.1/0, L:3.5/5.3, B:0.8/10.0, N:0/0/0
Jan 02, 2022 17:54:26.764 [0x00003b94] DEBUG - Parsec: [0] FPS:59.3/0, L:3.7/5.2, B:0.2/10.0, N:0/0/0
Jan 02, 2022 17:54:27.942 [0x00003b4c] DEBUG - Got WM_USER message, exiting.
Jan 02, 2022 17:54:27.966 [0x00003b4c] INFO - Retro: Game needs at most 356765 bytes to serialize.
Jan 02, 2022 17:54:27.968 [0x00003b4c] INFO - Retro: Serialization success to D:\Plex-Data\Plex Media Server\Game Saves\5\14d075b7c4b078ad4d56351ca4b2f2a24506e51\1\Snapshot.dat.
Jan 02, 2022 17:54:27.968 [0x00003b4c] DEBUG - Retro: Serialization not required for RAM.dat.
Jan 02, 2022 17:54:27.968 [0x00003b4c] DEBUG - Retro: Serialization not required for RTC.dat.
Jan 02, 2022 17:54:27.991 [0x00003b4c] DEBUG - Exiting.
