Problem with PR2100 NAS - Looking for servers
I have a problem with my Nas WD PR2100.
I installed the app for nas Plex Media Server.
When I start the app it opens to the ip address of the NAS 192.169.1.131:32400/web, then I log in.
The problem is that it does not allow me to create a new server, but keeps looking for the server I installed on my iMac.
I tried to:
  1. reinstall the app on the nas
  2. delete the server on iMac
  3. create a new plex user
But nothing, it open the web page as if it were a plex reader waiting for connection to a server.
Please help me!
Hi @dibi88
are you sure that the IP address 192.169.1.131 is correct? Shouldn’t it be 192.168.1.131?
Hi @JoergAndreas
Yes the ip is 192.169.1.131 becouse i have 2 router.
1st router is 192.168.1.1 thai is connected to internet in the first floor
2nd router connected via Ethernet to the 1st one with ip 192.169.1.1 in the second floor where i live.
The nas and all the devices (iMac/tv/iPad) are connected with the 2nd router.
Hi @dibi88
many thanks for clarification.
If you still cannot access the Plex Server on your My Cloud, best would be to open the My Cloud Web interface and stop/start the Plex service within the App Center. You should wait some minutes after you have started the Plex Server on your My Cloud until everything is up and running. Then connect again via :32400/web
One more question - or better spoken - problem localisation :
is the My Cloud PR4100 configured to get its IP via DHCP or have you set it to Static IP?
In case you are using Static IP, is this IP outside your DHCP range of your router?
Using Static IP within the DHCP range of the router is often the main issue for conenctivity problems.
I just tried to restart the app waiting a few minutes between the stop and the start and then between the start and the run of the app.
But nothing the app is always waiting for a new server.
The IP of the PR2100 is static and it is inside the range of the router, but in the router i reserved this IP 192.169.1.131 only for the nas.
Means “Static DHCP lease” assigned by the router, correct? Great!
Is the NAS then set to DHCP or Static? If it is set to Static with corresponding IP assigmnets, please switch to DHCP in the NAS network settings. As long as you are on Static IP within the NAS, the router will never get informed that this IP is in use (because the router will not receive any request) and therefore does not keep updated DNS information - which you need for the management.
Static DHCP lease is a great feature to avoid IP address changes, but then the client devices have to be set to DHCP - because the router will assign the individual IP addresses to the client devices and update its internal DNS.
If the client is set to Static IP address internally, the whole IP management inside the router will not work properly.
I’ve tried another thing.
I restored my 2nd router, then it was like i bought it with the IP 192.168.1.1 ( obviously without internet connection)
Then I connected the NAS with DHCP and the router assign 192.168.1.22
When I start the app with 192.168.1.22:32400/web it allowed me to configure as a server
Then I change the IP of the router because i need another IP (192.169.1.1) for network for the 2nd floor in my house and configure the connection to internet by residential gateway.
When I reboot the PR2100 it present another time the same problem (IP server 192.169.1.131:32400/web).
So the problem is with the network configuration but i don’t know why.
What router is it? Brand and model name, maybe I can assist.
If you have changed the router’s IP address from 192.168.1.1 to 192.169.1.1, you may need to take a look into its DHCP server too. You wrote
When I reboot the PR2100 it present another time the same problem (IP server 192.168.1.131:32400/web).
168 (old config) instead of 169 (new config)
If you move the router’s internal IP address segment, you should always reboot all attached clients to assign the new IP address segment to all clients. Sorry if this sounds educational, it’s not meant to sound like this.
In other words: your PC may stuck in a different IP segment than your NAS - which seems to be the issue here. Check the NAS IP address, either with the help of the WD Access software tool or by taken a look into the router’s DHCP server where you should see the NAS appearing with same IP address segment as your router (192.169.1.xyz). And of course check the PC’s IP address too.
The configuration is this:
INTERNET ----> VODAFONE STATION----)))wireless(((- netgear wifi extender ex3700
EX3700—ethernet---->DLINK DSL3590L-----ethernet---->WD PR2100
So for me the main router is the dlink, and I connect with the internet by a wifi range extender.
After every change of configuration i reboot the nas and the router
Thank you very much for all your time! :slight_smile:
I really don’t know what to do.
I edit the previous comment you’re right the NAS IP was 192.169.1.131
sorry. I wrote an error.
maybe i need to change something in the firewall adding some rules?
I solve the problem!
I change the IP of the second router in 192.168.2.1 and it solve the problem!
Thank you very much!
