Hi I have a problem when selecting subtiles in the following situation. When you watch a episode of a serie and at the end you let it autoplay to the next episode if you then try to adjust the player setting to select the required subtitle you get the settings of the previous played episode. So you have to stop playing completly and select the next episode (it still highlites the previous episode) and than you can select the subtitles for that episode.
This is a problem that exist with all releases of AppleTV I used in the past I’m now using 7.6.2 (1744)
