Problem with the New interface Plex on Apple TV and Nvidia Shield
I would like to thank the plex team for this new interface, but I have a display problem with the official version (photo), problem that I did not have with the test version. The picture is cut on the left
why add this sidebar, can you put an option to remove it in a future update, how can I solve my problem, no setting solves my screen cut
Check the overscan settings on your TV. The clock looks too far into the corner as well. The brand you have may call it "Picture Size, Scaling, or something similar instead of “overscan”
the problem is solved thank you for your help
It is in upscalling, I have deactivated the 16: 9 format
