I am running Plex on the latest version of Mac OS. I had it connected to an HDHomerun Connect. I recently added a HDHomerun Prime with a cable card. It is on Time Warner/Spectrum.
The Plex sees 186 channels on the HDHomRun Connect with 82 channels enabled.
Everything looks good.
On the HDHomeRun Prime it shows 247 channels shows but only 2 enabled. I want to enable more channels that are not DRM protected.
Unfortunately, most of the channels are showing up as “Protected.” I assume those are DRM channels. (I hate Time Warner/Spectrum. I recommend going to the FCC web page and filing an informal complaint about this DRM issue. Time Warner doesn’t need to do this. I also have a system on Comcast and those exact same channels are not DRM. Hopefully if there is enough complaints, the FCC will do something.)
I have about 10 channels that are not protected. There are two sections that show up when you enable/manage channels - Device Channels and Guid Channels.
When I check the box for a Device channel, there appears to be appears to be a probem with the Guide channels. Instead of showing the cable tv channels for the Guide Channels, it only shows me the guide for the over the air channels. At the top of the screen, it even says, “Local Over the Air Broadcast.” Instead of Cable. When I added the second DVR, it knew it was cable. I tried deleted the DVRs and setting them up again. I have the same problem. Is anyone else having this problem? Maybe you can only have one guide - over the air or cable and not both?
