I’m now having problems casting live TV where it’s now either choppy or buffers a lot. I have to downgrade the signal to 480p to get the signal to play smoothly and for some reason 720p will no longer work. Never had these problems before, what might be causing this?
What device are you using? There is a known bug for CCwGTV not being able to play 720p content.
I use Chromecasts on all my TVs and never had this problem until a recent update. So wonderful is this going to be fixed or do we just have to live with this now? Also is there any way to set a default of 480p so I don’t have to set the quality each time I change the channel?
The fix is in the current beta release.
Glad to hear it’s in the pipeline. Is the fix server side or client side?
Client side, 9.17 release.
I’m not able to stream live TV remotely, works fine when I’m on my local network , but when I’m trying to access Live TV remotely it doesn’t work, I can remotely access my media without any issue, Live TV used to work fine since updates it stopped working
