Hello Fellow Plex Users! I need help with TV shows that AREN’T as S01E01 format. But listed as in parts, or not even as parts. Here’s my problem.
V.The.Original.Miniseries.Part1.mkv
V.The.Original.Miniseries.Part2.mkv
V.The.Original.Miniseries.Part3.mkv
I tried: V > The Original Miniseries > Parts listed above
then tried: V The Original Miniseries > Season 1 > Parts listed above
But Plex doesn’t acknowledge the folder at all even after updating library.
This other problem, Plex will acknowledge the Main folder, but not all the files and even tries to put a few in season 1, 1 in season 20 and others aren’t even listed. I have several BBC Shows. Some are BBC Nature, Some BBC Nova and others just unspecified BBC shows. I’ve tried several combinations. Even renamed the source files on a few trying to get rid of the season 20 issue (Normally happens if you list 720p on file) But didn’t fix Issue. I temporarily individually placed them as single files in a home video folder without issues (but no meta data). Anyone ran across these problems and found out a way to get these to show up correctly?
TIA!
Max
