Server Version#: 1.32.4.7195
Player Version#: same?
Tuner Make/Model: netstream 4sat
Guide/Lineup name: Live TV(?)
Using XMLTV?: no
Channel number/Name: all german RTL-GROUP stations (RTL, SUPERRTL, NITRO, VOX etc)
Hi everybody.
I’m really new in PLEX Live TV as my user experience for eyeTV on MAC turned into really bad with the V4. So I came to PLEX and my setup is working well - except the streaming of German RTL Group stations. It doesn’t matter which carrier I use (some stations are available on different carriers e.g. for an Austrian version)…
…I also get stations on the same carriers (e.g. “TOGGO plus” on 12188) without any problems…
…but all RTL group stations on the same carrier (NITRO, NTV, RTL Television, RTLup, TRLZWEI, SUPER RTL, VOX) are not working.
Pls check the attached “Plex Tuner Service.log” for one try of a stream. I only see two errors - but I don’t know if these are relevant?
Jul 20, 2023 12:22:55.008 [0x7fa5c1857b38] WARN - [E] http_streamer_t::handle_read: read_error: End of file (2)
Jul 20, 2023 12:22:55.008 [0x7fa5c1754b38] WARN - [E] http_streamer_t: http write error
Perhaps there is somebody there who is able to help?
Many thanks in advance.
Jul 20, 2023 12:22:29.998 [0x7fa5c1754b38] INFO - [I] web_service_t::process_device_status
Jul 20, 2023 12:22:29.998 [0x7fa5c1754b38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 0
Jul 20, 2023 12:22:29.998 [0x7fa5c1754b38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:30.010 [0x7fa5c154eb38] INFO - [I] web_service_t::process_start_channel (device dvb#sat2ip#2#uuid:546f6d62-000c-6c0b-09fa-656c6761746f, channel triplet://1:1089:12060)
Jul 20, 2023 12:22:31.010 [0x7fa5c1754b38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:31.020 [0x7fa5c154eb38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 2
Jul 20, 2023 12:22:31.020 [0x7fa5c154eb38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:31.030 [0x7fa5c154eb38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:31.039 [0x7fa5c154eb38] INFO - [I] web_service_t::process_start_channel. Trying start channel triplet://1:1089:12060 on device dvb#sat2ip#2#uuid:546f6d62-000c-6c0b-09fa-656c6761746f (idx 0 out of 1 available)
Jul 20, 2023 12:22:31.039 [0x7fa5c154eb38] INFO - [I] device_manager_t::add_streamer. Channel triplet://1:1089:12060, device dvb#sat2ip#2#uuid:546f6d62-000c-6c0b-09fa-656c6761746f, streamer id 5151892d-f792-42ce-9d68-4651978d17a2
Jul 20, 2023 12:22:31.039 [0x7fa5c154eb38] INFO - [I] device_reactor_t::create_device dvb#sat2ip#2#uuid:546f6d62-000c-6c0b-09fa-656c6761746f
Jul 20, 2023 12:22:31.039 [0x7fa5c154eb38] INFO - [I] device_manager_t::add_streamer. Adding new streamer container for channel triplet://1:1089:12060 on device device dvb#sat2ip#2#uuid:546f6d62-000c-6c0b-09fa-656c6761746f.
Jul 20, 2023 12:22:31.040 [0x7fa5c154eb38] INFO - [I] transponder_streamer::start_idle_timer
Jul 20, 2023 12:22:31.040 [0x7fa5c154eb38] INFO - [I] tvs_program_streamer::tvs_program_streamer. Select program for nid 1, tid 1089, sid 12060
Jul 20, 2023 12:22:31.040 [0x7fa5bff82b38] INFO - [I] streamer_container_t::control_thread. Added streamer 5151892d-f792-42ce-9d68-4651978d17a2
Jul 20, 2023 12:22:31.040 [0x7fa5bff82b38] INFO - [I] streamer_container_t::control_thread. First streamer was added. Start program streamer
Jul 20, 2023 12:22:31.040 [0x7fa5bff82b38] INFO - [I] dvb_program_streamer_t::start. Starting program streamer for channel triplet://1:1089:12060
Jul 20, 2023 12:22:31.040 [0x7fa5bff82b38] INFO - [I] transponder_streamer::start_channel. Start request for channel triplet://1:1089:12060
Jul 20, 2023 12:22:31.040 [0x7fa5bff82b38] INFO - [I] transponder_streamer::stop_idle_timer
Jul 20, 2023 12:22:31.090 [0x7fa5c0085b38] INFO - [I] SAT2IP. Start device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 2
Jul 20, 2023 12:22:31.090 [0x7fa5c0085b38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:31.100 [0x7fa5c0085b38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:31.101 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 12188000, modulation 0, polarization 0, symbol rate 27500000, LOF 10600000, LNB selection signal 1, FEC 52
Jul 20, 2023 12:22:31.101 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::SelectLNB. Selecting LNB for diseqc value 0
Jul 20, 2023 12:22:31.101 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::prepare_rtp_session. Searching for free ports starting from base 28450
Jul 20, 2023 12:22:31.101 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::prepare_rtp_session. Found two free ports 28450 and 28451
Jul 20, 2023 12:22:31.101 [0x7fa5c0085b38] INFO - [I] get_sat2ip_tuning_string. Resulting string freq=12188&pol=h&msys=dvbs&mtype=qpsk&sr=27500&fec=34
Jul 20, 2023 12:22:31.101 [0x7fa5c0085b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: SETUP rtsp://192.168.100.101/?src=1&fe=3&freq=12188&pol=h&msys=dvbs&mtype=qpsk&sr=27500&fec=34&pids=0,21 RTSP/1.0
Transport: RTP/AVP;unicast;client_port=28450-28451
CSeq: 1
Jul 20, 2023 12:22:31.710 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::send_prepare_command. Succeeded. New stream ID is 98
Jul 20, 2023 12:22:31.710 [0x7fa5c0085b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: PLAY rtsp://192.168.100.101/stream=98?pids=0,21 RTSP/1.0
CSeq: 2
Session: 6CF03AD1
Jul 20, 2023 12:22:32.619 [0x7fa5bfd78b38] INFO - [I] sat2ip_streamer::control_thread_func. Control thread is started
Jul 20, 2023 12:22:32.619 [0x7fa5c0085b38] DEBUG - [I] sat2ip_streamer::start_reception. Trying to raise reception thread priority to 74
Jul 20, 2023 12:22:32.619 [0x7fa5bfe7bb38] INFO - [I] sat2ip_streamer::reception_thread_func. Reception thread is started
Jul 20, 2023 12:22:32.670 [0x7fa5bfd78b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: DESCRIBE rtsp://192.168.100.101/stream=98 RTSP/1.0
Accept: application/sdp
CSeq: 3
Session: 6CF03AD1
Jul 20, 2023 12:22:32.731 [0x7fa5bff82b38] INFO - [I] transponder_streamer::tune_transponder_impl. Signal stats: 100, 100, 1
Jul 20, 2023 12:22:32.731 [0x7fa5bfc75b38] INFO - [I] tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet://1:1089:12060
Jul 20, 2023 12:22:32.731 [0x7fa5c154eb38] INFO - [I] web_service_t::process_start_channel. Successfully started channel triplet://1:1089:12060 on device dvb#sat2ip#2#uuid:546f6d62-000c-6c0b-09fa-656c6761746f
Jul 20, 2023 12:22:32.731 [0x7fa5bfc75b38] INFO - [I] tvs_program_streamer::SetPATScanState. Waiting for PAT...
Jul 20, 2023 12:22:32.739 [0x7fa5c04cbb38] INFO - [I] http_streamer_t::send_thread_func: adding http client
Jul 20, 2023 12:22:32.781 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://1:1089:12060
Jul 20, 2023 12:22:32.781 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 0
Jul 20, 2023 12:22:32.831 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://1:1089:12060
Jul 20, 2023 12:22:32.832 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 1
Jul 20, 2023 12:22:32.832 [0x7fa5bfd78b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: PLAY rtsp://192.168.100.101/stream=98?pids=0,1,21 RTSP/1.0
CSeq: 4
Session: 6CF03AD1
Jul 20, 2023 12:22:34.021 [0x7fa5c1348b38] INFO - [I] web_service_t::process_device_status
Jul 20, 2023 12:22:34.021 [0x7fa5c1348b38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 0
Jul 20, 2023 12:22:34.022 [0x7fa5c1348b38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:34.031 [0x7fa5c1348b38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:34.342 [0x7fa5c0085b38] DEBUG - [I] required sid 12060
Jul 20, 2023 12:22:34.342 [0x7fa5c0085b38] DEBUG - [I] services (13): 12003, 12004, 12005, 12006, 12009, 12020, 12030, 12040, 12060,
Jul 20, 2023 12:22:34.342 [0x7fa5c0085b38] DEBUG - [I] pmt pid found: 47
Jul 20, 2023 12:22:34.342 [0x7fa5c0085b38] INFO - [I] Successfully parsed CAT CA descriptors
Jul 20, 2023 12:22:34.383 [0x7fa5bfc75b38] INFO - [I] tvs_program_streamer::tuning_thread. Waiting for PMT...
Jul 20, 2023 12:22:34.392 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 47, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.392 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 47
Jul 20, 2023 12:22:34.399 [0x7fa5bfd78b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: PLAY rtsp://192.168.100.101/stream=98?pids=0,1,21,47 RTSP/1.0
CSeq: 5
Session: 6CF03AD1
Jul 20, 2023 12:22:34.861 [0x7fa5c0085b38] INFO - [I] Successfully parsed CAT CA descriptors
Jul 20, 2023 12:22:34.894 [0x7fa5bfc75b38] INFO - [I] tvs_program_streamer::tuning_thread. PAT and PMT found. Checking CA descriptors
Jul 20, 2023 12:22:34.944 [0x7fa5bfc75b38] INFO - [I] tvs_program_streamer::tuning_thread. Start streaming
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 71, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 71
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 72, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 72
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 74, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 74
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 136, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 136
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 167, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 167
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 252, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 252
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 253, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 253
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.961 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.962 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 16, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.962 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 16
Jul 20, 2023 12:22:34.962 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 17, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.962 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 17
Jul 20, 2023 12:22:34.962 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 18, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.962 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::add_pid. Adding pid 18
Jul 20, 2023 12:22:34.962 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 8191, client triplet://1:1089:12060
Jul 20, 2023 12:22:34.962 [0x7fa5bfd78b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: PLAY rtsp://192.168.100.101/stream=98?pids=0,1,16,17,18,21,47,71,72,74,136,167,252,253 RTSP/1.0
CSeq: 6
Session: 6CF03AD1
Jul 20, 2023 12:22:35.012 [0x7fa5bfc75b38] INFO - [I] tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://1:1089:12060
Jul 20, 2023 12:22:35.097 [0x7fa5c0085b38] INFO - [I] CTSStreamWaiter::GetPidToCheck. PID to check 167
Jul 20, 2023 12:22:35.097 [0x7fa5c0085b38] INFO - [I] CTSStreamWaiter::GetVideoPid. Video PID 167
Jul 20, 2023 12:22:35.113 [0x7fa5c0085b38] INFO - [I] CTSStreamWaiter::ProcessStream. Found first not encrypted packet. Start streaming
Jul 20, 2023 12:22:37.040 [0x7fa5c1651b38] INFO - [I] web_service_t::process_device_status
Jul 20, 2023 12:22:37.040 [0x7fa5c1651b38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 0
Jul 20, 2023 12:22:37.040 [0x7fa5c1651b38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:38.051 [0x7fa5c1651b38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:41.063 [0x7fa5c144bb38] INFO - [I] web_service_t::process_device_status
Jul 20, 2023 12:22:41.063 [0x7fa5c144bb38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 0
Jul 20, 2023 12:22:41.063 [0x7fa5c144bb38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:41.072 [0x7fa5c144bb38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:42.626 [0x7fa5bfd78b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: OPTIONS rtsp://192.168.100.101/ RTSP/1.0
CSeq: 7
Session: 6CF03AD1
Jul 20, 2023 12:22:44.081 [0x7fa5c154eb38] INFO - [I] web_service_t::process_device_status
Jul 20, 2023 12:22:44.081 [0x7fa5c154eb38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 0
Jul 20, 2023 12:22:44.081 [0x7fa5c154eb38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:44.091 [0x7fa5c154eb38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:47.100 [0x7fa5c1348b38] INFO - [I] web_service_t::process_device_status
Jul 20, 2023 12:22:47.100 [0x7fa5c1348b38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 0
Jul 20, 2023 12:22:47.100 [0x7fa5c1348b38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:47.111 [0x7fa5c1348b38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:50.121 [0x7fa5c144bb38] INFO - [I] web_service_t::process_device_status
Jul 20, 2023 12:22:50.121 [0x7fa5c144bb38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 0
Jul 20, 2023 12:22:50.121 [0x7fa5c144bb38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:50.131 [0x7fa5c144bb38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:52.626 [0x7fa5bfd78b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: OPTIONS rtsp://192.168.100.101/ RTSP/1.0
CSeq: 8
Session: 6CF03AD1
Jul 20, 2023 12:22:53.144 [0x7fa5c1348b38] INFO - [I] web_service_t::process_device_status
Jul 20, 2023 12:22:53.144 [0x7fa5c1348b38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 0
Jul 20, 2023 12:22:53.144 [0x7fa5c1348b38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:53.151 [0x7fa5c1348b38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:55.007 [0x7fa5c144bb38] INFO - [I] web_service_t::process_device_status
Jul 20, 2023 12:22:55.007 [0x7fa5c144bb38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:546f6d62-000c-6c0b-09fa-656c6761746f, frontend index 0
Jul 20, 2023 12:22:55.007 [0x7fa5c144bb38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jul 20, 2023 12:22:55.008 [0x7fa5c04cbb38] INFO - [I] http_streamer_t::send_thread_func: removing http client
Jul 20, 2023 12:22:55.008 [0x7fa5c04cbb38] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Jul 20, 2023 12:22:55.009 [0x7fa5bff82b38] INFO - [I] streamer_container_t::control_thread. Removed disconnected streamer 5151892d-f792-42ce-9d68-4651978d17a2
Jul 20, 2023 12:22:55.009 [0x7fa5bff82b38] INFO - [I] streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Jul 20, 2023 12:22:55.009 [0x7fa5bff82b38] INFO - [I] dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://1:1089:12060
Jul 20, 2023 12:22:55.009 [0x7fa5bff82b38] INFO - [I] transponder_streamer::stop_channel. Stop request for channel triplet://1:1089:12060
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://1:1089:12060
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 0
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 1
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 16
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 17
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 18
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 47
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 71
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 72
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 74
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 136
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 167
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 252
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 253
Jul 20, 2023 12:22:55.014 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::delete_pid. Deleting pid 8191
Jul 20, 2023 12:22:55.014 [0x7fa5bff82b38] INFO - [I] transponder_streamer::start_idle_timer
Jul 20, 2023 12:22:55.015 [0x7fa5bfd78b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: PLAY rtsp://192.168.100.101/stream=98?pids=0,21 RTSP/1.0
CSeq: 9
Session: 6CF03AD1
Jul 20, 2023 12:22:55.024 [0x7fa5c144bb38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:546f6d62-000c-6c0b-09fa-656c6761746f at 192.168.100.101
Jul 20, 2023 12:22:56.191 [0x7fa5c1ac3b38] INFO - [I] device_manager_t::idle_timer_func. Stream container for channel triplet://1:1089:12060 on device dvb#sat2ip#2#uuid:546f6d62-000c-6c0b-09fa-656c6761746f is idle. Deleting it.
Jul 20, 2023 12:22:59.041 [0x7fa5c03c8b38] INFO - [I] Stopping graph
Jul 20, 2023 12:22:59.076 [0x7fa5bfd78b38] INFO - [I] sat2ip_streamer::control_thread_func. Control thread is finished
Jul 20, 2023 12:22:59.094 [0x7fa5bfe7bb38] INFO - [I] sat2ip_streamer::reception_thread_func. Reception thread is finished
Jul 20, 2023 12:22:59.095 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::stop. Deleting rtp session
Jul 20, 2023 12:22:59.095 [0x7fa5c0085b38] INFO - [I] sat2ip_streamer::send_teardown_command. Sending TEARDOWN command
Jul 20, 2023 12:22:59.095 [0x7fa5c0085b38] DEBUG - [I] sat2ip_streamer::sat2ip_send_command. Request: TEARDOWN rtsp://192.168.100.101/stream=98 RTSP/1.0
CSeq: 10
Session: 6CF03AD1
Jul 20, 2023 12:23:02.215 [0x7fa5c1ac3b38] INFO - [I] device_manager_t::idle_timer_func. Device dvb#sat2ip#2#uuid:546f6d62-000c-6c0b-09fa-656c6761746f is idle. Unloading it.
Jul 20, 2023 12:23:02.215 [0x7fa5c1ac3b38] INFO - [I] transponder_streamer::stop_idle_timer
Jul 20, 2023 12:23:02.215 [0x7fa5c1ac3b38] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Jul 20, 2023 12:23:02.246 [0x7fa5c1ac3b38] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Jul 20, 2023 12:23:02.246 [0x7fa5c1ac3b38] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Jul 20, 2023 12:23:03.243 [0x7fa5c03c8b38] INFO - [I] transponder_streamer::idle_thread_func finished
