Server Version#: >1.29
Player Version#: Web, Current Android and IOS Versions
Tuner Make/Model: dvb-S, netstream 4S
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name: RTL SD on Astra 19.2E
I found this topic already on other forums without solution. I run plex server on ubuntu 22.04 on proxmox with netstream 4S to distribute my satelite signal coming from a SAT multiswitch. Satelite is Astra 19.2E. All worked good until upgrade on server 1.40. After that senders of RTL group (RTL; RTLPLUS,…) in SD quality will be detected but not shown. Error occurs: code 50000, Transmitter could not be set.
I played around going back using older plex versions: 1.29 ist the last that works.
I tried with different setups even in different virtual machines, result is always the same.
Any idea?
