Problems with TV Show library
Hello all,
I am having a problem with adding TV shows to a library on my PMS. If I create a library and set it as a “movies” type and point it to a folder on my server it shows the files no problem. If I set it as “tv shows” type AND POINT IT TO THE SAME FOLDER nothing shows up…The problem is that it will not pull the metadata for TV shows in the movie type library… Any thoughts?
Thanks in advance
https://support.plex.tv/hc/en-us/articles/201543057-Why-is-some-of-my-content-not-found-
https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Season-Based-TV-Shows
Wow it worked! I thought I had done a good job naming them. Didn’t realize it was that picky!
