Program Guide not Loading
Since latest Plex Media Server update (plexpass), my PMS will refresh the Program Guide very quickly but will not show anything in the program guide, so none of my scheduled recordings occur. I even Deleted the DVR and set it up again, let it scan channels etc., still no go. I’m using the 3 Tuner HDHomeRun Prime with CableCard on Verizon FiOS. works great normally.
any thoughts on how to correct??? Plex Devs?
Noticed some other users pointing out FiOS channel 297 “SONLIFE” being the culprit. Unchecked this channel in mapping and EPG seems to be loading now, as slow as normal, but this is a good sign…probably the culprit but won’t know 100% for a while since it takes FOREVER for the EPG to load. but Sonlife Channel appears to most likely be the culprit
My PLEX Version 1.9.6.4429
I start to use this new feature DVR & Live TV.
I setup my channels and connect them to my custom xmltv EPG from https://teleguide.info/download/new3/xmltv.xml.gz
But my Program Guide is empty, even I see it’s synchronized, but something goes wrong…
