hey, i got a question. there is this small orange line (progress bar) at the bottom of my screen when in fullscreen mode.
see pic http://imgur.com/98eTfx5
is there a way to get rid of it? cause it gets really annoying.
might be a bit hard to see the line but its there
On what device? I don’t see it in Plex Web.
Useing chrome on Windows 10. Only have this problem on my Laptop havent seen it on my desktop so far
Does your laptop use an unusual screen resolution?
Did you activate a ‘zoom’ in the settings of your OS?
Nope havent activated any zoom funktion and useing 1920 x 1080
I can’t reproduce either here. So it must have something to do with your particular screen, web browser or system settings.
Alright Thanks for trying. I will try a reinstall on the webbrowser and if that dont help i will try a refresh on Windows 10
Hi, I got the same issue and can’t figure out how to remove it. I also thought it was a new feature from Plex. Did you find out what caused it?
@torgeha - where are you seeing this? We had an issue with the Xbox app with a ‘sticky’ progress bar, but I believe that should be fixed now.
Now that it’s fixed we get responses asking for clarification… this is a common theme
This problem has just started for me.
Plex media server on an iMac with Chrome in full screen mode.
Didn’t used to do this but now does.
Was there a solution?
SOLVED!
Issue with mine was that I had zoomed out in my Chrome. Resetting zoom fixed the issue.
Thank you!
