So, the question is not new, really: what is the right way to back up Plex [presumaby device-independent] metadata, which could be potentially restored to a different type of device without much pain?
Usual advice is to back up /share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server (official documentation suggests the same). The problem is that this also contains some shared libraries (read, architecture-specific binaries), so the backup is not architecture-independent.
Is there a better way to separate metadata from local crud?
Thanks in advance.
The technique is simple. This reply applies to you because of the installation path you have. Anyone can do this if they adjust the pathname appropriately.
- Create a shared folder and manually point it at
- Open the share in FileStation
- Stop PMS
- Create a ZIP of
Plex Media Server (Compress-ZIP)
- Copy/ move the ZIP file someplace safe
You now have a Plex share which also will give you easy access to your log files should PMS ever give you trouble and need to manually retrieve them
Huh?
On neither of mine do we have any binaries, except for codecs, which size is minimal
@ChuckPA
Remember this:
http://forums.plex.tv/discussion/234641
