I got a really annoying bug.
Whenever the player app is idle (not touching the PS3 remote or at the end of a movie), the app freeze with the loading bar (the three dots).
There is no way to recover the control except quitting the app (clicking the PS button and choosing quit) and relaunching it.
When we restart the app the video progress is not correct (if we ended a movie , it is still displayed at the middle and if we stopped in the middle it is displyed at somewhere before)
I tried to uninstall/reinstall the PS3 app with no better result.
This is crazy annoying so i stopped using the PS3 app because of this…
I have the exact same issues with PS3 and have also stop using my PS3 app because of it…
I seem to have recognized a minimum time pattern around 15 minutes. If you stop, pause or listen to something for under 15 minutes ish it’s fine. If I had to take a guest it’s a connectivity refresh or lack thereof.
I have a ps3 and have had this issue as well. I will not be renewing my subscription to Plex if this issue continues to occur, and will more to other alternatives. For clarification, the app will freeze at the end of a movie/show and I will have to force quit. Also, when browsing for a movie, it frequently freezes and I have to wait 20-30 seconds for it to unfreeze. There’s no way it should be doing this.
