PS4 Direct Stream with a natively supported MP4 file
I am curious as to why a natively supported MP4 file is being transcoded (albeit just the container).
From the Plex web site…
"Content matching the following can usually be Direct Played:
PS4
  • Container: MP4
  • Resolution: 1920×1080 or smaller
  • Video Encoding: H.264 (Level 4.1 or lower)
  • Audio Encoding: AAC, AC3, EAC3
  • Bitrate: 20Mbps or lower"
This is the source video file…
General
Complete name                            : movie.mp4
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom/iso2/avc1/mp41)
File size                                : 1.31 GiB
Duration                                 : 1 h 50 min
Overall bit rate                         : 1 692 kb/s
Writing application                      : Lavf58.42.102
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings                          : CABAC / 5 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 5 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 1 301 kb/s
Width                                    : 1 280 pixels
Height                                   : 694 pixels
Display aspect ratio                     : 1.85:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.061
Stream size                              : 1.00 GiB (77%)
Writing library                          : x264 core 160 r3000 33f9e14
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=2000 / vbv_bufsize=4000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Codec configuration box                  : avcC
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : ac-3
Bit rate mode                            : Constant
Bit rate                                 : 384 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 304 MiB (23%)
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Alternate group                          : 1
…and yet this is happening…
PRODUCT Plex for PlayStation 4
PLAYER PlayStation 4
QUALITY Original (1.7 Mbps)
STREAM Direct Stream
CONTAINER Transcode (MP4 > MPEGTS)
VIDEO Direct Stream (H264 720p)
AUDIO Direct Stream (AC3 5.1)
SUBTITLE None
Plex for Playstation 4 = 4.29.6
Plex Media Server = 1.19.4.2935
Thanks,
Paully
