PS4 Issues
First - thanks for the USA PS4 release, hoping now I can retire my roku. Unfortunately, not quite yet though...
I've noticed that when you start a show with non-hardcoded subtitles (like an .ass file attached) the show will display them - and in the correct size set by the settings!(unlike mr. roku). However, if you skip ahead, at all, the subtitles stop being displayed. Even turning them off, rebuffering, and then turning them back on and rebuffering doesn't fix the issue. Essentially, you have to not skip ahead...
The other issue I just noticed while testing the subtitle issue is this frame rate issue (?) - something I've never seen. It literally looked like the screen was jumping. Am I the only one having this issue?
Thanks!
Not a clue on your problem as I don't have a PS4, but try posting here: [Plex for PlayStation forums](https://forums.plex.tv/forum/153-plex-for-playstation/).
Better chance of the dev or someone with the same problem chiming in. :)
Thanks mate.
No problem, hopefully you get it figured out.
