After the latest Plex update on my PS4 Pro the dashboard wont load. I’ve found a way round this by removing the app and reinstalling then re-logging in, using the plex tvlink code and all is good until I restart Plex then the same problem
br3nn88
November 20, 2018, 8:09pm
2
I have friends with this issue,
Can anyone confirm how long until the next ps4 release?
Have been discusted in This topic. No solution or anything gotten from the tram
Exactly the same problem as others like @thomy22 and @SimonaGhera
I have tried a rollback, but this is just not possible
The only way to get it to work it to uninstall it, reinstall it, go through the process of adding the code on your computer and then you can watch it. As soon as you leave Plex, you have to go through the process again.
Why update something without testing it first?
Updates are meant to be improvements, this update fails on every level, from functionality to appearance (do…
system
Closed
February 18, 2019, 11:27pm
4
