Server Version#: QNAP TS-1655 (QTS) v5.2.0.2802 (2024/06/20)
Player Version#: Plex Web Version 4.134.2
GPU#: NVIDIA Corporation TU106 (GeForce GTX 1650) - Set to QTS Mode
Goal: Use Raid 1 2TB storage pool/vol I created JUST for PLEX web stream transcoding.
Drive Config: Raid 1 volume with 2 x 2TB SSD with folder /transcode (2TB is size free)
PLEX Config: Have GPU transcoding set. Set Transcoding temporary directory to /transcode. See image below
Issue: When I stream something that requires transcoding, I get a playback Error with message “Not enough disk space to convert this item.”
I go look beneath /transcode and I do see that the following folder structure was created, so seems I have the path correct but cannot understand the issue as I have plenty of free space.
/transcode/Transcode/
/Sessions
Possible something with the path I give? Maybe I cannot point to symbolic link or maybe I need to. I cannot find much info on how to structure that path and what I am suppose to see in that directory
Thanks much
Kirk
